Anisotropic thermal conductivity in CHT SimpleFoam
Old   April 21, 2022, 05:57
Default Anisotropic thermal conductivity in CHT SimpleFoam
Sunag R A
sunagra27 is on a distinguished road
Dear all,
I am running an anisotropic thermal conductivity using chtMultiRegionSimpleFoam solver. The simulation has two solid regions. Spherical region embedded inside a hemispherical region named as tumor and gland. I have attached the case file for reference.
Thermophysical property:
1. The anisotropic thermal properties for both the regions are as mentioned below:
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      solidThermophysicalProperties;
thermoType
    type            heSolidThermo;
    mixture         pureMixture;
	transport       constAnIso;
    //transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
coordinateSystem
    type    cartesian;  // global co-ordinate system (redundant)
    origin  (0.006713780918727913 0.032 -0.006082474226804117);
    coordinateRotation
        type    cylindrical; // local Cartesian co-ordinates
        //e3      (0 0 0);
        e3      (0 0 1); // axis of rotation
mixture
    specie
      molWeight   0;
    transport
		kappa   (0.48 0.1 0.1);
        //kappa   0.51;
    thermodynamics
        Hf      0;
        Cp      3770;
    equationOfState
        rho     1050;
Problem:
1. From the above thermophysical property, I could understand that the heat will flow radially since it has mode kappa value and directed along the z axis of rotation.
2. Based on this understanding, I expect my resulting simulation such that the heat from the internal sphere should move upwards (y coordinate in design) acting as a source. The outer boundary is impemented with convection BC with an ambient temperature of 22, while the spherical tumor source is having initial temperature of 38. The simulation is steady state.
But, in my simulation, the heat is moving downwards as it can be seen after the simulation in the image presented below. I tried the axis values with (-1) and also with other direction like tangential kappa.
What is wrong in my thermophysical properties as such?
I have attached the complete project file in a zip.
Simulation image after 100 iterations.
https://drive.google.com/file/d/1SaR...ew?usp=sharing
Zip_file link
https://drive.google.com/file/d/1WVh...ew?usp=sharing
1. The file is of size 84 MB. Please run and provide if anything missing.
2. The mesh has been run, please run "chtMultiRegionSimpleFoam" and create all.foam later on to check the results.
Please feel free to check other boundary conditions also and provide feedback so that I can improve upon the problem.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
anisotropic, anisotropic conductivity, kappa, openfoam, thermophysical
Anisotropic Thermal Conductivity in CFX 16.0 ZahirUZ CFX 4 March 27, 2019 05:54
Question about anisotropic thermal conductivity Szweyk STAR-CCM+ 2 June 30, 2016 09:26
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 11:38
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 18:26
Anisotropic Thermal Conductivity Saturn CFX 4 January 30, 2007 13:34
