open Channel, interFoam simulation keep numerically exploding |
April 18, 2022, 05:27 |
Miguel Hernandez
Rep Power: 5 |
Hi all,
I am running an interFoam simulation, an open channel flowing into a natural stream via a dissipation structure (stilling basin tipe IV). For the first run I was planning to simulate 40 seconds total. The simulation runs smoothly for the first seconds; I arrived in the best case at 29 seconds of simulation, then the simulation continues to "explode". I checked the mesh - it's not great - but with checkMesh I have no errors. At the inlet, my intention is set a known flow velocity that varies linearly in time until arriving to the wished value. I was wondering at this point if my BCs are correct. Can someone help me, please? These are my BCs: US_Channel is the upstream channel (artificial channel) DS_Channel is the downstream channel (natural river) Vasca_Carico is a fictitious loading tank located at the upstream end of the model Dissipatore is the dissipative structure (concrete) Inlet Outlet Atm_sx is a patch on the left side of the model, outlet in the atmosphere - only air - Atm_dx is a patch on the right side of the model, outlet in the atmosphere - only air - atm is a patch on the top of the model, outlet in the atmosphere - only air - alpha.water Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { US_Channel { type zeroGradient; } DS_Channel { type zeroGradient; } Vasca_Carico { type zeroGradient; } Inlet { type fixedValue; value uniform 1; } Outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } Atm_sx { type inletOutlet; inletValue uniform 0; value uniform 0; } Atm_dx { type inletOutlet; inletValue uniform 0; value uniform 0; } Dissipatore { type zeroGradient; } atm { type inletOutlet; inletValue uniform 0; value uniform 0; } } Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.01078; boundaryField { US_Channel { type epsilonWallFunction; value uniform 0; } DS_Channel { type epsilonWallFunction; value uniform 0; } Vasca_Carico { type epsilonWallFunction; value uniform 0; } Inlet { type fixedValue; value $internalField;//uniform 0.01078 } Outlet { type inletOutlet; inletValue $internalField; value $internalField; } Atm_sx { type inletOutlet; inletValue $internalField; value $internalField; } Atm_dx { type inletOutlet; inletValue $internalField; value $internalField; } Dissipatore { type epsilonWallFunction; value uniform 0; } atm { type inletOutlet; inletValue $internalField; value $internalField; } } Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.015; boundaryField { US_Channel { type kqRWallFunction; value uniform 0.1; } DS_Channel { type kqRWallFunction; value uniform 0.1; } Vasca_Carico { type kqRWallFunction; value uniform 0.1; } Inlet { type fixedValue; value $internalField; } Outlet { type inletOutlet; inletValue $internalField; value $internalField; } Atm_sx { type inletOutlet; inletValue $internalField; value $internalField; } Atm_dx { type inletOutlet; inletValue $internalField; value $internalField; } Dissipatore { type kqRWallFunction; value uniform 0.0; } atm { type inletOutlet; inletValue $internalField; value $internalField; } } Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { US_Channel { type nutkRoughWallFunction; Ks uniform 0.05; Cs uniform 0.5; value uniform 0; } DS_Channel { type nutkRoughWallFunction; Ks uniform 0.05; Cs uniform 0.5; value uniform 0; } Vasca_Carico { type nutkWallFunction; value uniform 0; } Inlet { type calculated; value uniform 0; } Outlet { type calculated; value uniform 0; } Atm_sx { type calculated; value uniform 0; } Atm_dx { type calculated; value uniform 0; } Dissipatore { type nutkRoughWallFunction; Ks uniform 0.002; Cs uniform 0.5; value uniform 0; } atm { type calculated; value uniform 0; } } p_rgh Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { US_Channel { type fixedFluxPressure; gradient uniform 0; value uniform 0; } DS_Channel { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Vasca_Carico { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Inlet { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Outlet { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Atm_sx { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Atm_dx { type fixedFluxPressure; gradient uniform 0; value uniform 0; } Dissipatore { type fixedFluxPressure; gradient uniform 0; value uniform 0; } atm { type totalPressure; p0 uniform 0; /* rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0;*/ } } Code:
FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { US_Channel { type noSlip; } DS_Channel { type noSlip; } Vasca_Carico { type noSlip; } Inlet { type uniformFixedValue; uniformValue table; uniformValueCoeffs { values 2 ( (0 (0 0 0)) (1.5 (0.5 0 0)) ) ; } value uniform (0 0 0); } Outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } Atm_sx { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } Atm_dx { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } Dissipatore { type noSlip; } atm { type pressureInletOutletVelocity; value uniform (0 0 0); } } fvSchemes Code:
FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(rhoPhi,k) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(rhoPhi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default orthogonal;//corrected } Code:
FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.water.*" { nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } "pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0.05; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; /*In transient simulations, it is usual to set the solver relative tolerance to 0 to force the solution to converge to the solver tolerance in each time step.*/ relTol 0;//0.05 } p_rghFinal { $p_rgh; relTol 0; } "(U|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0.1; minIter 1; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; //1 nCorrectors 3; nNonOrthogonalCorrectors 1; //1 } relaxationFactors { equations { ".*" 1; } } |
April 18, 2022, 13:53 |
Uwe Pilz
Rep Power: 15 |
You may try using first order divSchemes first.
If this does not help: Calculate to the timere where all is ok, reduce the time step and look where teh "exploding starts". It would be helpful for us if you make a skecth of this result. May be something is wrong with your b.c.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 18, 2022, 16:07 |
Miguel Hernandez
Rep Power: 5 |
I've modified the fvSolution, the simulation runs smoothly til 29.6 seconds... Than there is a continuity error, for what I understand ( see please below....)
FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.water.*" { nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; //added MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; //1e-08 relTol 0; } "pcorr.*" { solver GAMG;//PCG preconditioner DIC; smoother GaussSeidel;//Add by pol tolerance 1e-10; //1e-10 relTol 0; } p_rgh { solver GAMG; tolerance 1e-4; //1e-7 relTol 0.01; smoother GaussSeidel; //DIC nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; //false nCellsInCoarsestLevel 2090;//1000 agglomerator faceAreaPair; mergeLevels 1; } p_rghFinal { solver GAMG; tolerance 1e-6; //1e-7 relTol 0.0; smoother GaussSeidel; //DIC nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; //false nCellsInCoarsestLevel 2090;//1000 agglomerator faceAreaPair; mergeLevels 1; /*$p_rgh; tolerance 1e-09;//1e-09 relTol 0;*/ } "(U|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; nSweep 1; tolerance 1e-08; //1e-08 relTol 0.1; } UFinal { $U; relTol 0; } } PIMPLE { momentumPredictor no;//no nOuterCorrectors 50; //1 nCorrectors 5; //3 nNonOrthogonalCorrectors 1; //1 correctPhi yes; residualControl { U { tolerance 1e-03; relTol 0; } p_rgh { tolerance 1e-03; relTol 0; } } } relaxationFactors { equations { ".*" 1; } } Code:
Courant Number mean: 0.00872699 max: 0.498106 Interface Courant Number mean: 0.0028107 max: 0.498106 deltaT = 0.00181341 Time = 29.6728 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 4.95598e-05, Final residual = 2.81908e-11, No Iterations 2 Phase-1 volume fraction = 0.0743685 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.0743685 Min(alpha.water) = 0 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 4.95599e-05, Final residual = 2.82273e-11, No Iterations 2 Phase-1 volume fraction = 0.0743701 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.0743701 Min(alpha.water) = 0 Max(alpha.water) = 1 Setting residual field for first solver iteration for solver field: p_rgh GAMG: Solving for p_rgh, Initial residual = 0.00258632, Final residual = 8.67018e-05, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000611305, Final residual = 7.03293e-05, No Iterations 1 time step continuity errors : sum local = 5.69794e-05, global = 9.86179e-06, cumulative = -0.0137937 GAMG: Solving for p_rgh, Initial residual = 0.327079, Final residual = 0.00261458, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.0600958, Final residual = 0.000503613, No Iterations 5 time step continuity errors : sum local = 0.00120971, global = 2.13181e-05, cumulative = -0.0137724 GAMG: Solving for p_rgh, Initial residual = 0.999777, Final residual = 0.0072521, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.0310123, Final residual = 0.000135246, No Iterations 7 time step continuity errors : sum local = 10.5254, global = 0.739539, cumulative = 0.725766 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00917299, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.0391282, Final residual = 0.000295516, No Iterations 6 time step continuity errors : sum local = 1.99456e+10, global = 1.29176e+08, cumulative = 1.29176e+08 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00788926, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.0308159, Final residual = 7.83812e-07, No Iterations 19 time step continuity errors : sum local = 2.82235e+25, global = 1.83278e+24, cumulative = 1.83278e+24 PIMPLE: iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 0.000217746, Final residual = 8.86914e-09, No Iterations 64 Phase-1 volume fraction = 6.48819e-07 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = -539.784 Min(alpha.water) = -4.15712e+25 Max(alpha.water) = 2.51495e+25 smoothSolver: Solving for alpha.water, Initial residual = 1, Final residual = 4.85524e-09, No Iterations 12 Phase-1 volume fraction = -2.58774e+14 Min(alpha.water) = -5.62831e+17 Max(alpha.water) = 3.8513e+17 MULES: Correcting alpha.water Phase-1 volume fraction = 1.95218e+44 Min(alpha.water) = -1.81229e+66 Max(alpha.water) = 2.32406e+66 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00894108, No Iterations 50 GAMG: Solving for p_rgh, Initial residual = 3.20506e-26, Final residual = 3.20506e-26, No Iterations 0 time step continuity errors : sum local = 1.04794e+56, global = 1.16607e+40, cumulative = 1.16607e+40 GAMG: Solving for p_rgh, Initial residual = 0.0569763, Final residual = 0.000388805, No Iterations 7 GAMG: Solving for p_rgh, Initial residual = 4.38524e-26, Final residual = 4.38524e-26, No Iterations 0 time step continuity errors : sum local = 2.11986e+94, global = 1.20331e+78, cumulative = 1.20331e+78 [9] #0 Foam::error::printStack(Foam::Ostream&)sh: addr2line: command not found addr2line failed [9] #1 Foam::sigFpe::sigHandler(int)sh: addr2line: command not found addr2line failed [9] #2 sh: which: command not found __kernel_rt_sigreturn [9] #3 Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)sh: addr2line: command not found addr2line failed [9] #4 Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constsh: addr2line: command not found addr2line failed [9] #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) constsh: addr2line: command not found addr2line failed [9] #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) constsh: addr2line: command not found addr2line failed [9] #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constsh: addr2line: command not found addr2line failed [9] #8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)sh: addr2line: command not found addr2line failed [9] #9 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&)sh: addr2line: command not found addr2line failed [9] #10 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) constsh: addr2line: command not found addr2line failed [9] #11 sh: which: command not found ? [9] #12 __libc_start_mainsh: addr2line: command not found addr2line failed [9] #13 sh: which: command not found ? [1e57e9171cd2:445 :0:445] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) ==== backtrace (tid: 445) ==== 0 /usr/lib64/libucs.so.0(ucs_handle_error+0x114) [0xffff817f4a94] 1 /usr/lib64/libucs.so.0(+0x22dcc) [0xffff817f4dcc] 2 /usr/lib64/libucs.so.0(+0x22fa4) [0xffff817f4fa4] 3 linux-vdso.so.1(__kernel_rt_sigreturn+0) [0xffff8c2247c0] 4 /lib64/libpthread.so.0(raise+0xb0) [0xffff86de1e48] 5 linux-vdso.so.1(__kernel_rt_sigreturn+0) [0xffff8c2247c0] 6 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEENS_13scalarProductIT_S2_E4typeERKNS_5UListIS2_EES8_+0x44) [0xffff879a6af4] 7 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG11scalarSolveERNS_5FieldIdEERKS2_h+0x648) [0xffff877cb418] 8 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarsestLevelERNS_5FieldIdEERKS2_+0xa8) [0xffff877f17e8] 9 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x450) [0xffff877f3a68] 10 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x478) [0xffff877f5750] 11 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x44c) [0xffff8ab276dc] 12 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x368) [0xffff8a3bf300] 13 /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x1c) [0xffff8a369004] 14 interFoam() [0x44cd78] 15 /lib64/libc.so.6(__libc_start_main+0xe8) [0xffff86c69fa0] 16 interFoam() [0x452688] ================================= [1e57e9171cd2:00445] *** Process received signal *** [1e57e9171cd2:00445] Signal: Floating point exception (8) [1e57e9171cd2:00445] Signal code: (-6) [1e57e9171cd2:00445] Failing at address: 0x1f5000001bd [1e57e9171cd2:00445] [ 0] linux-vdso.so.1(__kernel_rt_sigreturn+0x0)[0xffff8c2247c0] [1e57e9171cd2:00445] [ 1] /lib64/libpthread.so.0(raise+0xb0)[0xffff86de1e48] [1e57e9171cd2:00445] [ 2] linux-vdso.so.1(__kernel_rt_sigreturn+0x0)[0xffff8c2247c0] [1e57e9171cd2:00445] [ 3] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEENS_13scalarProductIT_S2_E4typeERKNS_5UListIS2_EES8_+0x44)[0xffff879a6af4] [1e57e9171cd2:00445] [ 4] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG11scalarSolveERNS_5FieldIdEERKS2_h+0x648)[0xffff877cb418] [1e57e9171cd2:00445] [ 5] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver18solveCoarsestLevelERNS_5FieldIdEERKS2_+0xa8)[0xffff877f17e8] [1e57e9171cd2:00445] [ 6] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x450)[0xffff877f3a68] [1e57e9171cd2:00445] [ 7] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x478)[0xffff877f5750] [1e57e9171cd2:00445] [ 8] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x44c)[0xffff8ab276dc] [1e57e9171cd2:00445] [ 9] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x368)[0xffff8a3bf300] [1e57e9171cd2:00445] [10] /usr/lib/openfoam/openfoam2112/platforms/linuxARM64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x1c)[0xffff8a369004] [1e57e9171cd2:00445] [11] interFoam[0x44cd78] [1e57e9171cd2:00445] [12] /lib64/libc.so.6(__libc_start_main+0xe8)[0xffff86c69fa0] [1e57e9171cd2:00445] [13] interFoam[0x452688] [1e57e9171cd2:00445] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 9 with PID 0 on node 1e57e9171cd2 exited on signal 8 (Floating point exception). ----------------------------------------------------- I don't have any ideas.... |
April 19, 2022, 03:17 |
Uwe Pilz
Rep Power: 15 |
Before you get a floating point exception you get often very high values for pressure and/ or velocity. It is important to find out where that starts. Run up to 29 seconds, reduce the time step (or the Courant number), and observe with paraview where the irregularity starts.
April 19, 2022, 09:25 |
#5 | |
Santiago Lopez Castano
Rep Power: 16 |
April 19, 2022, 11:34 |
#6 | |
Miguel Hernandez
Rep Power: 5 |
I've tried to figured out with paraview as you suggested, without any success unfortunately, I'm not able to understand what is going on in my model. Currently, I'm trying a new mesh, let's see what will happen.... Thanks again for your suggestions... |
April 19, 2022, 11:40 |
#7 | |
Miguel Hernandez
Rep Power: 5 |
Do you mean to change, in the transient stage, the BCs in the nut file from nutkRoughWallFunction (for the channels and the dissipative structure) with nutkWallFunction? My intent was to simulate the roughness of the channel and the stilling basins being made of different materials (natural channel VS concrete)... something like is usually done in Hec-Ras, for example, e.g. setting a manning coefficient of 0.035 for natural channels and 0.014 for concrete.... |
April 20, 2022, 09:20 |
#8 | |
Rep Power: 16 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
Open Channel Flow Simulation | physicosm | OpenFOAM Running, Solving & CFD | 0 | December 6, 2019 08:06 |
Fluent Open Channel Simulation | ahammack | Fluent Multiphase | 0 | October 12, 2016 13:58 |
