Foam::error::printStack(Foam::Ostream&) when number of processors increases |
April 18, 2022, 04:30 |
Yanyan Xie
Rep Power: 5 |
My program runs well when I set 5 processors in parallel. However, when I change to 10 processors. This problem occurs. Anyone knows any reason with this? I just can't figure it out.
Starting time loop Time = 0 Courant Number mean: 0.249727 max: 4.03023 rank: 8, Number of outside parcels is: 0 rank: 9, Number of outside parcels is: 0 rank: 0, Number of outside parcels is: 0 rank: 2, Number of outside parcels is: 0 rank: 1, Number of outside parcels is: 0 rank: 7, Number of outside parcels is: 0 rank: 3, Number of outside parcels is: 0 rank: 5, Number of outside parcels is: 0 rank: 6, Number of outside parcels is: 0 rank: 4, Number of outside parcels is: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.000218222, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.000175145, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.000419464, No Iterations 3 GAMGPCG: Solving for p, Initial residual = 1, Final residual = 9.36043e-06, No Iterations 5 GAMGPCG: Solving for p, Initial residual = 0.388308, Final residual = 3.06702e-05, No Iterations 3 time step continuity errors : sum local = 2.56381e-06, global = 3.36418e-09, cumulative = 3.36418e-09 GAMGPCG: Solving for p, Initial residual = 0.0864754, Final residual = 3.15506e-05, No Iterations 3 GAMGPCG: Solving for p, Initial residual = 0.106596, Final residual = 2.08671e-07, No Iterations 4 time step continuity errors : sum local = 1.97629e-08, global = 3.86717e-12, cumulative = 3.36805e-09 [9] [2] #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&)[0] [8] #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [8] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [9] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::sigSegv::sigHandler(int)[7] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [0] #2 ? in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [8] #2 ? in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [9] #2 ? in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [2] #2 ?[3] #0 Foam::error:rintStack(Foam::Ostream&) in "/lib64/libpthread.so.0" [0] #3 in "/lib64/libpthread.so.0" [8] #3 in "/lib64/libpthread.so.0" [9] #3 ? in "/lib64/libpthread.so.0" [2] #3 ? in "/lib64/libpthread.so.0" [9] #4 __libc_start_main in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [1] #2 ? in "/lib64/libpthread.so.0" [2] #4 __libc_start_main in "/lib64/libc.so.6" [9] #5 ? in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" [7] #1 Foam::sigSegv::sigHandler(int) in "/lib64/libc.so.6" [2] #5 ? in "/lib64/libc.so.6" in "/lib64/libpthread.so.0" [1] #3 in "/lib64/libc.so.6" sh: addr2line: command not found APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) |
Foam-Extend 4.0 simpleFoam motorbike parallel error? | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 10, 2021 05:55 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 04:58 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
