April 13, 2022, 10:32 |
OpenFoam v9 - how to rotate searchableBox
Mary
Rep Power: 5 |
In OpenFoam v9, how to rotate searchableBox? Code:
geometry { buildings { type triSurfaceMesh; file "buildings.stl"; } refinementBox { type searchableBox; min (-80 -80 0); max (80 80 190); } }; In OpenFoam v9, I am not sure if 'searchableRotatedBox' works or not. Please help, Thanks Last edited by limpideyes; April 13, 2022 at 16:48. |
April 17, 2022, 16:25 |
Rep Power: 21 |
You can't with searchableBox, but there should be a version that is rotated likely called searchableRotatedBox. Atleast that is present in the ESI versions. Or simply create an stl with the dimensions and position you desire. (For example in paraview and save as an stl)
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 20:20 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[mesh manipulation] rotate mesh in OpenFOAM | kiddmax | OpenFOAM Meshing & Mesh Conversion | 1 | February 22, 2014 15:12 |
