Petsc Wrong Results
Old   April 13, 2022, 05:16
Default Petsc Wrong Results
Arwa wadhane
Arwa_Wadhane is on a distinguished road
I m calling Petsc (conjugate gradient algorithm) in my code, when I run it with mpiexec -n 8 ,it gives wrong results. and when I run it with mpiexec -n 1 it gives good results .can someone help me please?
Arwa_Wadhane is offline   Reply With Quote
Old   April 18, 2022, 13:18
Domenico Lahaye
dlahaye is on a distinguished road
I imagine PETSc (beware of spelling) solver setting to be the culprit here.
With increase in subdomains, the preconditioned becomes less effective.
Run with output of PETSc convergence history on and increase accuracy of linear solver.
Get in touch here in case you would like more input.
dlahaye is offline   Reply With Quote
[OpenFOAM] Wrong results of Paraview plots in case patch WhiteW ParaView 0 May 20, 2021 09:14
Wrong Results with PimpleFoam Egalov OpenFOAM 0 September 2, 2018 08:53
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 11:45
wrong results after use UDF turbulent viscosity lehoanganh07 Fluent UDF and Scheme Programming 0 July 21, 2014 12:12
interFoam 2.1.x gives wrong results on low Froude numbers lt.quibbler OpenFOAM Running, Solving & CFD 12 June 14, 2012 09:06
