Multiphase euler foam problem with velocity vector
Old   April 12, 2022, 03:48
Post Multiphase euler foam problem with velocity vector
Akshay
enthusiast is on a distinguished road
hello!! I am using Open foam version 8, I am trying to simulate a two-phase (gas-liquid) separator with 3 inlets with baffle plates and two outlets for both phases.
The liquid velocity at the gas outlet keeps increasing gradually as the simulation time prolongs (my liquid velocity reaches abysmal values). Due to this my time step is increasing with it.
There should be no water at the gas outlet but somehow the solver is calculating unrealistic water velocity at the gas outlet.
I have shared the discretization schemes implemented and also my boundary conditions used for multiphaseEulerFoam. I have even shared the velocity vector slice in the geometry and the checkMesh.
Also I have specifies the phase properties and I am using mixtureKEpsilon turbulence model
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.oxygen;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
	inlet1
        type            fixedValue;
        value           uniform 0.3238;
	inlet2
        type            fixedValue;
	inlet3
        type            fixedValue;
	walls
        type            zeroGradient;
	baffle1
        type            zeroGradient;
	baffle2
        type            zeroGradient;
	baffle3
        type            zeroGradient;
    outlet1
        type            inletOutlet;
        phi             phi.oxygen;
        inletValue      uniform 0;
        value           uniform 0;
	outlet2
        type            inletOutlet;
        phi             phi.oxygen;
        inletValue      uniform 1;
        value           uniform 1;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.water;
internalField   uniform 0;
boundaryField
	inlet1
        type            fixedValue;
        value           uniform 0.6762;
	inlet2
        type            fixedValue;
	inlet3
        type            fixedValue;
	walls
        type            zeroGradient;
	baffle1
        type            zeroGradient;
	baffle2
        type            zeroGradient;
	baffle3
        type            zeroGradient;
    outlet1
        type            inletOutlet;
        phi             phi.water;
        value           uniform 1;
	outlet2
        type            inletOutlet;
        phi             phi.water;
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions          [1 -1 -2 0 0 0 0];
internalField       uniform 4e5;
boundaryField
    inlet1
        type               calculated;
        value              $internalField;
	inlet2
        type               calculated;
	inlet3
        type               calculated;
	walls
        type               calculated;
	baffle1
        type               calculated;
	baffle2
        type               calculated;
	baffle3
        type               calculated;
    outlet1
        type               calculated;
	outlet2
        type               calculated;
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
boundaryField
    inlet1
        type               fixedFluxPressure;
	inlet2
	inlet3
	walls
	baffle1
	baffle2
	baffle3
    outlet1
        type               prghPressure;
        p                  $internalField;
    outlet2
        type               prghPressure;
        p                  $internalField;
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    object      U.oxygen;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet1
        type            fixedValue;
        value           uniform (0 0 1.4);
	inlet2
        type            fixedValue;
	inlet3
        type            fixedValue;
        value           uniform (0 0 -1.4);
	walls
        type               slip;
	baffle1
        type               slip;
	baffle2
        type               slip;
	baffle3
        type               slip;
    outlet1
        type               pressureInletOutletVelocity;
        phi                phi.oxygen;
    outlet2
        phi                phi.oxygen;
FoamFile
    version     2.0;
    format      binary;
    object      U.water;
boundaryField
    inlet1
        type            fixedValue;
        value           uniform (0 0 2.92);
	inlet2
        type            fixedValue;
	inlet3
        type            fixedValue;
        value           uniform (0 0 -2.92);
	walls
        type               noSlip;
	baffle1
        type               noSlip;
	baffle2
        type               noSlip;
	baffle3
        type               noSlip;
    outlet1
        phi                phi.water;
    outlet2
        phi                phi.water;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         CrankNicolson 0; //Euler;
gradSchemes
    default			cellLimited Gauss linear 1;
	grad(U)			cellLimited Gauss linear 1;
	//default         Gauss linear;
divSchemes
    default                         			none;
    div(phi,alpha.oxygen)              			Gauss vanLeer;
    div(phi,alpha.water)            			Gauss vanLeer;
    div(phir,alpha.water,alpha.oxygen) 			Gauss vanLeer;
    div(phir,alpha.oxygen,alpha.water) 			Gauss vanLeer;
    "div\(alphaRhoPhi.*,U.*\)"      			Gauss linearUpwindV grad(U); //Gauss limitedLinearV 1;
    "div\(phi.*,U.*\)"              			Gauss linearUpwindV grad(U); //Gauss limitedLinearV 1;
    "div\(alphaRhoPhi.*,(h|e).*\)"  			Gauss linearUpwind default; //Gauss limitedLinear 1;
    "div\(alphaRhoPhi.*,K.*\)"      			Gauss linearUpwind default; //Gauss limitedLinear 1;
    "div\(alphaPhi.*,p\)"           			Gauss linearUpwind default; //Gauss limitedLinear 1;
    "div\(alphaRhoPhi.*,(k|epsilon|omega).*\)"  Gauss linearUpwind default; //Gauss limitedLinear 1;
    "div\(phim,(k|epsilon)m\)"      			Gauss linearUpwind default; //Gauss limitedLinear 1;
    "div\(\(\(\(alpha.*\*thermo:rho.*\)*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
laplacianSchemes
    default         Gauss linear limited 1; //Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 1; //uncorrected;
wallDist
    method          meshWave;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.*"
        nAlphaCorr      1;
        nAlphaSubCycles 2;
    p_rgh
        solver          GAMG;
        smoother        DIC;
        tolerance       1e-8;
        relTol          0.01;
		minIter         1;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "U.*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-5;
        relTol          0;
        minIter         1;
    "e.*"
        //tolerance       1e-7;
        relTol          2;
        minIter         0;
    "(k|epsilon|Theta|omega).*"
        tolerance       1e-7;
        relTol          0;
        minIter         5;
	yPsi
        solver          PCG;
        preconditioner  none;
        tolerance       1e-10;
        relTol          0;
PIMPLE
    nOuterCorrectors 3;
    nCorrectors      1;
    nNonOrthogonalCorrectors 1;
	//faceMomentum        yes;
	//explicitTurbulentNormalStress true;
relaxationFactors
    equations
        ".*"            1;
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            529375
    internal faces:   499745
    cells:            168877
    faces per cell:   6.0939
    boundary patches: 9
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     150668
    prisms:        8752
    wedges:        0
    pyramids:      0
    tet wedges:    36
    tetrahedra:    2
    polyhedra:     9419
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   651
            5   462
            6   2307
            7   33
            8   58
            9   3476
           10   10
           11   9
           12   1989
           13   5
           15   403
           18   16
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
                 baffle1     2324     2368  ok (non-closed singly connected)
                 baffle2     2278     2326  ok (non-closed singly connected)
                 baffle3     2297     2349  ok (non-closed singly connected)
                  inlet1      108      134  ok (non-closed singly connected)
                  inlet2      109      134  ok (non-closed singly connected)
                  inlet3      101      116  ok (non-closed singly connected)
                 outlet1       66       77  ok (non-closed singly connected)
                 outlet2        6        8  ok (non-closed singly connected)
                   walls    22341    23345  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.133186 -0.299184 -0.369699) (2.436 0.299196 0.366711)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-6.9755e-17 -1.089e-16 1.1863e-16) OK.
    Max cell openness = 3.188e-16 OK.
    Max aspect ratio = 6.84199 OK.
    Minimum face area = 5.66589e-07. Maximum face area = 0.000931798.  Face area magnitudes OK.
    Min volume = 1.86129e-08. Max volume = 2.73649e-05.  Total volume = 0.671561.  Cell volumes OK.
    Mesh non-orthogonality Max: 44.9987 average: 7.56959
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.86891 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      phaseProperties;
type    basicMultiphaseSystem;
phases (oxygen water);
oxygen
    type            purePhaseModel;
    diameterModel   constant;
    constantCoeffs
        d               2e-3;
    residualAlpha   1e-6;
water
    constantCoeffs
        d               1e-4;
    residualAlpha   1e-6;
blending
	default
        type            linear;
        minFullyContinuousAlpha.oxygen 0.7;
        minPartlyContinuousAlpha.oxygen 0.3;
        minFullyContinuousAlpha.water 0.7;
        minPartlyContinuousAlpha.water 0.3;
	default
        type            hyperbolic;
		transitionAlphaScale 0.6;
        minContinuousAlpha.oxygen 0.4;
        minContinuousAlpha.water 0.6;
    default
        type            none;
        continuousPhase water;
surfaceTension
    (oxygen and water)
        type            constant;
        sigma           0.0644;
aspectRatio
    (oxygen in water)
        type            constant;
        E0              1.0;
    (water in oxygen)
        type            constant;
        E0              1.0;
drag
	(oxygen in water)
        type            SchillerNaumann;
        residualRe      1e-3;
        swarmCorrection
            type        none;
    (oxygen in water)
        type            IshiiZuber;
        residualRe      1e-3;
        swarmCorrection
            type        none;
			//l 			1.75;
virtualMass
    (oxygen in water)
        type            constantCoefficient;
        Cvm             0.5;
	(water in oxygen)
        Cvm             0.5;
heatTransfer
    (oxygen in water)
        type            RanzMarshall;
        residualAlpha   1e-4;
	(water in oxygen)
        type            RanzMarshall;
        residualAlpha   1e-4;
phaseTransfer
lift
    (oxygen in water)
		Cl             0.5;
wallLubrication
    (oxygen in water)
        type            Antal;
        Cw1             -0.01;
		Cw2				0.05;
turbulentDispersion
    (oxygen in water)
        Ctd               	0.5;
interfaceCompression
// Minimum allowable pressure
pMin            10000;
I have disabled solving for energy equations by making it not solve for energy equation in fvsolution since my case is isothermal.
If anybody could please guide me on what mistake I am making, it will be really helpful for me.
Thank you
Last edited by enthusiast; April 13, 2022 at 04:55. Reason: Filling in the missing information
enthusiast is offline   Reply With Quote
Old   January 20, 2023, 04:54
evamaria is on a distinguished road
Could you also share the phase fraction snapshots?
I suppose it might be a problem, how you specified the alpha.water and alpha.oxygen at the outlet.
If you are sure, that for one outlet only water is going out and for the other only oxygen, you could set the phase fractions in that way.
evamaria is offline   Reply With Quote
multi phase flow, numerical computation, time step decreasing
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
