Rotating deformable pipe with internal and external axial flow
Old   April 11, 2022, 07:13
Question Rotating deformable pipe with internal and external axial flow
Vi Kumar
grokkingStuff is on a distinguished road
Hey all,
I’m trying to model a drill string such that the solid material rotates about its longitudinal axis and is affected by internal and external axial flow.
I think I’ve managed to make the case with a stationary deformable pipe, with fluid flowing internally and externally. This is akin to a drill string that isn’t rotating.
I’ve been using solids4foam but I’m not sure how to use a rotating mesh with solids4foam
grokkingStuff is offline   Reply With Quote
fluid solid coupling, fluid solid interaction, rotating cylinder, solids4foam
External flow or Internal flow boundary domain dinhanh Main CFD Forum 0 June 4, 2017 07:43
Simulating internal & external pipe flow simultaneously 30na FLUENT 0 March 11, 2015 12:44
modeling a pipe with both internal and external flow amir_14 FLUENT 4 July 9, 2014 18:18
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 04:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
