polynomial transport properties for fluid flow |
April 7, 2022, 06:38 |
Almanzo Arjuna
Rep Power: 4 |
Hi, I'm running a simulation using chtMultiRegionFoam to simulate a high-pressure water heating through a tube.
For the water thermophysical properties I want to use my custom thermophysical properties for water, but I encounter some problem when using the polynomial transport thermotype Code:
thermoType { type heRhoThermo; mixture pureMixture; transport polynomial; thermo hPolynomial; equationOfState rPolynomial; specie specie; energy sensibleEnthalpy; } Code:
Using dynamicCode for codedBase heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___ at line 17 in "/opt/openfoam9/etc/codeTemplates/dynamicCode/fluidReactionThermo" Creating new library in "dynamicCode/heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___/platforms/linux64GccDPInt32Opt/lib/libheRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy____e26ffcb6217e5d317f54afd3df2824cd5b221ddb.so" "/opt/openfoam9/etc/codeTemplates/dynamicCode/fluidReactionThermoTemplate.C" "/mnt/f/OpenFOAM/almanzolin-9/run/2dSubChannelFlow/dynamicCode/heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___/fluidReactionThermoTemplate.C" Invoking "wmake -s libso /mnt/f/OpenFOAM/almanzolin-9/run/2dSubChannelFlow/dynamicCode/heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___" wmake libso /mnt/f/OpenFOAM/almanzolin-9/run/2dSubChannelFlow/dynamicCode/heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___ make: Warning: File 'Make/options' has modification time 1.1 s in the future make: warning: Clock skew detected. Your build may be incomplete. make: Warning: File 'Make/linux64GccDPInt32Opt/files' has modification time 0.79 s in the future ln: ./lnInclude ln: failed to create symbolic link './fluidReactionThermoTemplate.C': Operation not permitted make: warning: Clock skew detected. Your build may be incomplete. make: Warning: File 'Make/linux64GccDPInt32Opt/files' has modification time 0.29 s in the future wmkdep: fluidReactionThermoTemplate.C make: Warning: File 'Make/linux64GccDPInt32Opt/fluidReactionThermoTemplate.C.dep' has modification time 1.7 s in the future Ctoo: fluidReactionThermoTemplate.C ld: /mnt/f/OpenFOAM/almanzolin-9/run/2dSubChannelFlow/dynamicCode/heRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy___/../platforms/linux64GccDPInt32Opt/lib/libheRhoThermo_pureMixture_polynomial_hPolynomial_rPolynomial_specie___sensibleEnthalpy____e26ffcb6217e5d317f54afd3df2824cd5b221ddb.so make: warning: Clock skew detected. Your build may be incomplete. Code:
Solving for fluid region flow DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 5.7518128e-07, No Iterations 2 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 1.5753742e-07, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 2.5052526e-08, No Iterations 2 Min/max T:534.14723 580.05242 GAMG: Solving for p_rgh, Initial residual = 0.99999996, Final residual = 5.3751159, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.095647115, Final residual = 0.089695488, No Iterations 100 time step continuity errors : sum local = 5.2066267e-05, global = -1.839178e-06, cumulative = -1.839178e-06 GAMG: Solving for p_rgh, Initial residual = 0.065094164, Final residual = 0.032569178, No Iterations 100 GAMG: Solving for p_rgh, Initial residual = 0.02923575, Final residual = 0.029177399, No Iterations 100 time step continuity errors : sum local = 3.278726e-05, global = 3.2052265e-06, cumulative = 1.3660485e-06 DILUPBiCGStab: Solving for omega, Initial residual = 0.0034782107, Final residual = 1.09506e-09, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 1.3992301e-08, No Iterations 1 Do you guys also encounter this problem? Thanks. |
chtmultiregionfoam, polynomial, thermophysical properties |
Non-uniform transport properties in openFoam | fetc95 | OpenFOAM Programming & Development | 3 | November 2, 2023 21:04 |
Variable transport properties | silviliril | OpenFOAM Pre-Processing | 1 | July 1, 2022 10:19 |
Modified polynomial thermophysical and transport properties | tijan | OpenFOAM Running, Solving & CFD | 1 | August 20, 2021 02:49 |
Sample case of simplified energy transport simulation for incompressible flow | fumiya | OpenFOAM Community Contributions | 0 | September 20, 2020 07:42 |
Species Transport Convergence trouble in Supersonic Flow | BrianF16 | FLUENT | 0 | February 28, 2017 12:18 |
