April 1, 2022, 06:14 |
simpleFoam kOmegaSSt boundary conditions
Sean
Rep Power: 4 |
Hi everyone,
I’m a long time visitor and lurker on the forum. Today I’m making my first post! Thank you in advance I’m struggling to get a simpleFoam kOmegaSST turbulence model to run on OF7. The cases existed in the department, though I had to make two changes to get simpleFoam to run:
I have a working case of kOmegaSST which has largely the same BC, although in that case the inlet and outlet are cyclic so I cannot compare the inlet and outlet. I have tried many different values, settings and wall functions but the results remains wrong. Can anybody help me spot the issue? Due to the interpolated values the files are too large to attach, please see a summary of the 0 directory below. If anyone requires more information or files please let me know! U: internalField --- nonuniform List (interpolated LES data) inlet ------------ fixedValue nonuniform List (… fully developed channel flow) topWall --------- fixedValue uniform(0 0 0) bottomWall----- fixedValue uniform(0 0 0) outlet ---------- zeroGradient p: internalField --- nonuniform List (interpolated LES data) inlet ------------ zeroGradient topWall --------- zeroGradient bottomWall----- zeroGradient outlet ---------- fixedValue uniform(0) nut: internalField -- nonuniform List (interpolated LES data) inlet ------------ calculated nonuniform List (… fully developed channel flow?) topWall -------- nutLowReWallFunction uniform 3e-18 bottomWall---- nutLowReWallFunction uniform 3e-18 outlet --------- calculated nonuniform List (… fully developed channel flow?) both top and bottom walls had “calculated” instead of “nutLowReWallFunction”, but simplefoam couldn’t run with calculated. I think nutLowReWallFunction is appropriate. omega: internalField ---- uniform 0.11 inlet ------------ fixedValue nonuniform List (… fully developed channel flow?) topWall --------- omegaWallFunction uniform 1000 bottomWall----- omegaWallFunction uniform 1000 outlet ---------- zeroGradient k: internalField ---- nonuniform List (interpolated LES data) inlet ------------- fixedValue nonuniform List (interpolated LES data) topWall --------- fixedValue uniform 1e-15 bottomWall----- all fixedValue uniform 1e-15 outlet ---------- zeroGradient Last edited by DataDriven; April 1, 2022 at 11:32. |
boundary condition, initial conditions, komegasst, simplefoam, simplefoam initialisation |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
