Adding a Heat Source - OpenFOAM v2112 chtMultiRegionTwoPhaseEulerFoam
Old   April 1, 2022, 06:59
Default Adding a Heat Source - OpenFOAM v2112 chtMultiRegionTwoPhaseEulerFoam
Magnox is on a distinguished road
Hi everyone,
I'm trying to use chtMultiRegionTwoPhaseEulerFoam to create a simulation of a heater submerged in water. However, I'm not sure how to add a heat source of constant flux to the heater region in OpenFOAM v2112. I've tried the approaches from the tutorials for OpenFOAM 9, to no success, and can't seem to understand how the heat sources are defined in the OpenFOAM v2112 multi region solver tutorials.
Please may some one be able to give me some guidance about how I can add a heat source to a region in OpenFOAM v2112 for use with the chtMultiRegionTwoPhaseEulerFoam solver.
Many thanks.
Follow-Up Question Edit: can a flux heat source be added to the same boundary as one defined using the compressible::turbulentTemperatureTwoPhaseRadCoupl edMixed boundary condition?
Magnox is offline   Reply With Quote
Defining a Heat Source in OpenFOAM v2112 for chtMultiRegionTwoPhaseulerFoam Magnox OpenFOAM Running, Solving & CFD 0 March 29, 2022 16:33
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
