Density averaging the surface tension term in interFoam |
March 30, 2022, 11:32 |
Venkat Ganesh
Rep Power: 6 |
Hey multiphase researchers, I'm trying a standard modification to the surface tension term in interFoam which has been suggested in Brackbill's paper on CSF method, which is to include a density averaging term in the surface tension force term calculation. (I've shared an image of the equation)
In code within openfoam, the current surface tension force term without the density averaging is implemented as Code:
fvc::interpolate(sigmaK())*fvc::snGrad(alpha1) Code:
fvc::interpolate(sigmaK()*rho)*fvc::snGrad(alpha1)*2/(rho1+rho2) I'm sharing an image of the bubble shape I obtained using the current code for reference. It would be great if someone could confirm if they've faced similar issues with adopting the change as well. "Brackbill, J. U., Kothe, D. B., & Zemach, C. (1992). A continuum method for modeling surface tension. Journal of computational physics, 100(2), 335-354." |
csf model, interfoam, surface tension |
Plotting Surface tension force with interfoam | Mahmoud_aboukhedr | OpenFOAM Programming & Development | 5 | December 1, 2016 08:37 |
Surface tension Interfoam | nb977 | OpenFOAM Running, Solving & CFD | 1 | March 9, 2016 03:02 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? | SJSW | Fluent Multiphase | 2 | November 18, 2014 04:15 |
Flame Surface Density. | Burn Ing | Main CFD Forum | 3 | December 5, 2004 17:12 |
