pimpleFoam -dict
Old   March 30, 2022, 07:33
Default pimpleFoam -dict
ghastbug is on a distinguished road
snappyHexMesh allows usage of -dict. So if I have several snappyHexMeshDict files in my case/system, I can tell openFoam which to use.
Example: snappyHexMesh -dict system/snappyHexMeshDictIChose
Is there a way to do the same with pimpleFoam?
ghastbug is offline   Reply With Quote
Old   March 30, 2022, 11:57
Tobermory will become famous soon enough
Doesn't look like you can. You can tell it to use a different case directory, with the -case flag, but that's probably not what you are after ..
I am guessing you want to have say 2 or 3 controlDicts, each with different run parameters, and then run pimpleFoam with each one? I would do that all through scripting. i.e. either have the 3 files in your system folder, names controlDict.1, controlDict.2 etc., and then use the script to copy each one to controlDict and then run.
Alternatively just have one controlDict and do all the manipulations in the script, using the foamDictionary utility to update the parameters for each run.
Hope that helps.
Tobermory is offline   Reply With Quote
pimpleFoam runs slower than rhoPimpleFoam Kosuke Seto OpenFOAM Running, Solving & CFD 3 May 27, 2023 15:12
Running pimpleFoam in steady state trailer OpenFOAM Running, Solving & CFD 6 January 24, 2023 04:07
fail to run series of runApplication topoSet -dict jiahui_93 OpenFOAM Programming & Development 1 May 25, 2022 13:56
pisoFoam and pimpleFoam are unstable in foam-extend 4.0/4.1 (misunderstanding ?) Kombinator OpenFOAM Running, Solving & CFD 4 January 14, 2021 05:10
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
