some errors when use icofoam at first step
Old   March 30, 2022, 03:39
Question some errors when use icofoam at first step
NIUMENG
niumeng is on a distinguished road
Dear teachers and students, I intend to use icofoam to calculate a grid transformed from ICEM. When using icofoam for trial operation, the following errors occur. The first step is wrong. What is the problem? The mesh in ICEM contains an interface. Instead, cyclicami is set in openfoam. I guess there is a problem in this step because the area of adjacent surfaces of the interface is inconsistent. I think cyclicami's introduction seems to say that the size of adjacent surfaces should be the same.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
Build : 9-710dba47639b
Exec : icoFoam
Date : Mar 22 2022
Time : 20:18:23
Host : "nm"
PID : 58789
I/O : uncollated
Case : /home/nm/OpenFOAM/nm/cavityceshi2/cavity
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
AMI: Creating addressing and weights between 151 source faces and 134 target faces
AMI: Patch source sum(weights) min/max/average = 0, 1, 0.841191
AMI: Patch target sum(weights) min/max/average = 0, 1, 0.813281
Starting time loop
Time = 0.0005
Courant Number mean: 0 max: 0
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 9.17761e-06, No Iterations 77
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.92611e-06, No Iterations 97
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 9.44364e-06, No Iterations 71
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4 ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#5 ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
浮点数例外 (核心已转储)
nm@nm:~/OpenFOAM/nm/cavityceshi2/cavity$
niumeng is offline   Reply With Quote
icofoam, interface.cyclicami
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
