interFoam: forces computation for planing hulls
Old   March 29, 2022, 07:31
Default interFoam: forces computation for planing hulls
Daniele Peri
DanielePeri is on a distinguished road
Hi!
I am simulating a planing hull (Fr = 2.5) using interFoam. I compute forces by using the DTChull example, but I am not sure about the treatment of the air entrainment.
As far as I understand, the lib (forces) is able to discriminate between wetted and dry portions of the hull surface, but it is not clear to me what happens when, in some (relevant) parts of the hull, alpha.water is not 0 or 1. By the way, only the water density is explicitly assigned, and not the air density... and air resistance becomes not negligible in this case.
There is something I can do in order to properly compute forces in such a situation or what I am doing is enough?
Thanks
Daniele
DanielePeri is offline   Reply With Quote
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
forces functionObject with interFoam and dynamic pressure AnnaF OpenFOAM Post-Processing 4 June 20, 2019 21:46
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 11:42
Measure forces on wall with interFoam jrrygg OpenFOAM Pre-Processing 0 November 5, 2012 09:20
forces in interFoam Svensson OpenFOAM Post-Processing 2 May 9, 2012 14:31
