Variable Courant number
Old   March 21, 2022, 13:22
Default Variable Courant number
Andrea
Dezzo is on a distinguished road
Dear all,
this is my first post on the forum, so please be patient if I made silly questions, and please be patient also if this is not the correct place…
Going to the topic, I’m using rhoPimpleFoam to solve a steady case and I would like to modify the Courant number (in order to reduce the computational time) automatically during the simulation, for example in a sinusoidal way, since I’m only interested on final values (p, T, U, rho).
I looked for something similar in the forum, I found the some this for example:
how to get current time as scalar?
So I tried to wrote something like:
[c]aMax 10; //amplitude
maxCo #eval "($aMax+0.5)-(($aMax)*(cos(2*3.14159*$runTime.value()/$endTime)))"; // sine wave with min value 0.5 at start and at endTime=0.005
[/c]
I got
[c]FOAM FATAL ERROR
Syntax error in expression at position:42
(10.00000+1)-((10.00000)*(cos(2*3.14159*/0.005000)))
^^^^ near here[/c]
I also tried to add:
[c]scalar t=time().value()[/c]
instead of runTime.value()
I also tried many little modifications but I was not able to make it to work correctly.
Can someone show me the right way?
Many thanks!
Dezzo is offline   Reply With Quote
Old   April 1, 2022, 04:27
Andrea
I was able to manage the issue in a pragmatic way using the function object timeActivatedFileUpdate:
fileUpdate
        type            timeActivatedFileUpdate;
        libs (utilityFunctionObjects);
        writeControl   timeStep;
        writeInterval  1;
        fileToUpdate    "$FOAM_CASE/system/controlDict";
        timeVsFile
            (-1    "$FOAM_CASE/system/controlDict_1")
            (#eval "($endTime*0.02)"    "$FOAM_CASE/system/controlDict_2")
            (#eval "($endTime*0.05)"    "$FOAM_CASE/system/controlDict_5")
            (#eval "($endTime*0.95)"    "$FOAM_CASE/system/controlDict_2")
            (#eval "($endTime*0.98)"    "$FOAM_CASE/system/controlDict_1")
Varing the Courant number in each controlDict file.
But I’m still looking for something more elegant.
Thanks
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
