March 20, 2022, 06:40 |
Why Cl, Cd and Cm is unrealisitic?
FOAMraj
Rep Power: 5 |
I am simulating an unsteady incompressible flow over the pentagon. I am using komegasst turbulence model in pimpleFoam solver.
Here is the image of forceCoeff: https://imgur.com/7rUyWEX Here is the image of mesh: https://imgur.com/S5nnjMq Here is the velocity simulation image: https://imgur.com/yYyXd7Y Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.192 0 0); boundaryField { inlet { type fixedValue; value uniform (0.192 0 0); } outlet { type zeroGradient; } wall { type fixedValue; value uniform (0 0 0); } obstacle { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // The pressure boundary condition: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } wall { type zeroGradient; } obstacle { type zeroGradient; } frontAndBack { type empty; } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // |
external aerodynamics, force coefficients, turbulence analysis |
