Defined pressure drop between two fluid regions
Old   March 11, 2022, 00:12
Default Defined pressure drop between two fluid regions
Desh
dasith0001 is on a distinguished road
Hi Formers,
I have this question for some time and I could not yet figure out a way to do it. Here is my question.
1. There is two fluid domains with same thermophysical properties. Each fluid domain can have a inlet and a outlet. (fluid domains should have at lease one external boundary)
2. Two domains are physically connected by a narrow channel.
3. I want to define a pressure gradient between the internal surfaces of the narrow channel. ( so that the narrow channel basically acts as a relief valve).
Could you suggest me an any direction setting up such a case? Or is it even possible to do this in OpenFoam ? Your help is greatly appreciated.
Thank you.
Dasith
dasith0001 is offline   Reply With Quote
Old   March 31, 2023, 00:26
Desh
Can anyone give me a hint ?
Defined pressure gradient between two fluid regions dasith0001 OpenFOAM Running, Solving & CFD 4 March 16, 2022 21:14
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 12:30
