BC combination:s slip walls with turbulence model
Old   March 9, 2022, 11:02
Default BC combination:s slip walls with turbulence model
Friendly is on a distinguished road
Hi everyone,
I would like to start a Simulation that contains slip walls and a turbulence model (kOmegaSST). I am not sure about the BCs when I use slip walls in U.
Is it right to keep:
k: kqRWallFunction
omega: omegaWallFunction
nut: nutkWallFunction
alphat: alphatWallFunction
or should I rather apply a zeroGradient BC? As far as I understood, the kqRWallFunction wall function is basically a zeroGradient BC.
Thanks in advance!
Friendly
Friendly is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Treatment of rough walls with SST turbulence model R4z0rX CFX 5 November 27, 2019 16:02
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
