Floating point exception - interFoam, kOmegaSST |
March 8, 2022, 21:33 |
Zulkar Nayem
Rep Power: 10 |
Hello everyone
I am trying to calculate resistance of wigley hull with interFoam solver in OpenFOAM 9. Used following base case. tutorials/multiphase/interFoam/RAS/DTCHull Just changed the geometry stl file and changed relevant values in some files. Run the solver in single core. Solver is giving the following error after running 80-90 time steps. Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::magSqr<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #4 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> > >, Foam::IncompressibleMomentumTransportModel<Foam::kinematicTransportModel> >::correct() at ??:? #5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" Floating point exception (core dumped) Code:
Mesh stats points: 1826029 faces: 5286320 internal faces: 5205924 cells: 1731246 faces per cell: 6.06052 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 1638870 prisms: 7727 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 84649 Breakdown of polyhedra by number of faces: faces number of cells 4 1403 5 1230 6 1458 7 62037 8 1069 9 17452 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology atmosphere 798 860 ok (non-closed singly connected) inlet 3382 3580 ok (non-closed singly connected) outlet 3382 3580 ok (non-closed singly connected) bottom 798 860 ok (non-closed singly connected) side 7476 7697 ok (non-closed singly connected) midPlane 29595 30776 ok (non-closed singly connected) hull 34965 36843 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-26 -19 -16) (16 3.51072e-12 4) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.66952e-16 1.95783e-15 -1.02697e-16) OK. Max cell openness = 4.12411e-16 OK. Max aspect ratio = 71.827 OK. Minimum face area = 1.26253e-05. Maximum face area = 1.00711. Face area magnitudes OK. Min volume = 7.66276e-08. Max volume = 0.934091. Total volume = 15957.3. Cell volumes OK. Mesh non-orthogonality Max: 69.9801 average: 5.7433 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.99295 OK. Coupled point location match (average 0) OK. Mesh OK. Code:
ddtSchemes { default localEuler; } gradSchemes { default Gauss linear; limitedGrad cellLimited Gauss linear 1; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss interfaceCompression vanLeer 1; div(phi,k) Gauss linearUpwind limitedGrad; div(phi,omega) Gauss linearUpwind limitedGrad; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 1; MULESCorr yes; nLimiterIter 10; alphaApplyPrevCorr yes; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; minIter 1; } "pcorr.*" { solver PCG; preconditioner { preconditioner GAMG; smoother GaussSeidel; tolerance 1e-5; relTol 0; }; tolerance 1e-5; relTol 0; }; p_rgh { solver GAMG; smoother DIC; tolerance 1e-7; relTol 0.01; }; p_rghFinal { $p_rgh; relTol 0; } "(U|k|omega).*" { solver smoothSolver; smoother symGaussSeidel; nSweeps 1; tolerance 1e-7; relTol 0.1; minIter 1; }; } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; maxCo 10; maxAlphaCo 5; rDeltaTSmoothingCoeff 0.05; rDeltaTDampingCoeff 0.5; nAlphaSpreadIter 0; nAlphaSweepIter 0; maxDeltaT 1; } relaxationFactors { equations { ".*" 1; } } cache { grad(U); } Also find the case directory here. I am new to OpenFOAM. Can you help me? Thanks. Last edited by nayem.cosmic; March 9, 2022 at 20:40. |
March 9, 2022, 20:41 |
Zulkar Nayem
Rep Power: 10 |
Update:
Solved my issue. Changed relaxation factor to below 1 in fvSolution file. Code:
relaxationFactors { equations { ".*" 0.7; } } |
November 22, 2023, 05:54 |
Chandra Napitupulu
Rep Power: 3 |
I'm just wondering, why should be it at 0.7? I've tried my submarine simulation, and the last solver, it gives the same error. could you tell me?
November 22, 2023, 07:05 |
Zulkar Nayem
Rep Power: 10 |
There is no fixed value as far as I know. You might lower the value and try.
November 22, 2023, 20:57 |
Chandra Napitupulu
Rep Power: 3 |
interfoam hull, komega sst model, resistance estimation, wigleyhull |
Understanding The Floating Point Exception Error Message | RussellHolt | OpenFOAM Running, Solving & CFD | 2 | August 6, 2022 01:00 |
rhoCentralFoam - kOmegaSST - Floating point exception | DGW | OpenFOAM Running, Solving & CFD | 1 | September 1, 2016 08:45 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 05:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 14:56 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 06:58 |
