dynamicMotionSolverFvMeshAMI with 6DoF motion |
March 4, 2022, 06:28 |
Felix Weiler
Rep Power: 9 |
Dear Foamers,
in the past, I have successfully set up the sixDoFRigidBodyMotion solver with AMI patches to separate a rotating cell region from a static surrounding. Now I wanted to make use of the improved numerics implemented in dynamicMotionSolverFvMeshAMI. Now when I use sixDoFRigidBodyMotion as motionSolver, nothing happens. I traced this to this particular change: dynamicMotionSolverFvMesh.C Code:
fvMesh::movePoints(motionPtr_->newPoints()); Code:
pointField newPoints(motionPtr_->curPoints()); if(changeRequired { [...] polyTopo.movePoints(newPoints); } else { fvMesh::movePoints(newPoints); } dynamicMotionSolverFvMeshAMI.C Code:
pointField newPoints(motionPtr_->newPoints()); Maybe someone can elaborate on the improved numerics, too, as I don't really understand, what's happening there. Kind regards, Felix Last edited by benchwell; March 4, 2022 at 06:29. Reason: Added file names for clarity |
August 18, 2023, 03:23 |
TWB
Rep Power: 19 |
Hi benchwell,
Did you manage to find your ans? I wonder if the reason the sixDOF did not work is because the new AMI with topological changes is not absorbed into the standard dynamicMotionSolverFvMesh model? Btw, you mentioned that you change the dynamicMotionSolverFvMeshAMI.C. So did you create a new dynamicMotionSolverFvMeshAMI model and re-compile it? And the sixDOF worked w/o any problem after that? Thanks. |
Use of a laplacian mesh motion solver with the 6DoF or rigidBodyMotion libraries | tecmul | OpenFOAM Running, Solving & CFD | 8 | February 11, 2022 10:59 |
6DOF for spring valve motion problem | ahehuhehuh | Fluent UDF and Scheme Programming | 2 | April 18, 2018 15:39 |
Error in flow driven motion using cyclicAMI and 6DoF | ashish.kumar | OpenFOAM Running, Solving & CFD | 0 | August 27, 2017 10:43 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 11:37 |
