Rep Power: 4 ![]() |
hello i am beginner of openfoam !
when i studied the heat transfer example related to "multiphaseEulerFoam", i had a question.. i set the toposet to give heat the region set by toposet, and i confirmed that the heat from heatsource in fvoption is released.. so i thought that the change of temperature will occur.. because of heat that i set. but temperature is consistent at 300K.. so i wanted to know the reason why temperature of region(or material) is same .. from what i checked, i noticed the reason. because i set "internalfield uniform 300;". i want to see the change of temperature according to heat. how can i do this? change uniform to non uniform?? thank you ! |
Change in velocity w.r.t specefic cell/zone temperature UDF | hlmehr | Fluent UDF and Scheme Programming | 4 | August 31, 2019 11:09 |
Change in velocity w.r.t specefic cell/zone temperature UDF | hlmehr | FLUENT | 0 | July 13, 2019 10:06 |
Introduce a change in temperature through a subdomain | hand90 | CFX | 1 | September 2, 2018 06:56 |
Conjugate heat transfer with phase change produced wrong temperature | qtruong | OpenFOAM Programming & Development | 0 | July 10, 2018 14:16 |
About rate of change of density and temperature | susu | Main CFD Forum | 0 | February 13, 2013 05:55 |
