February 22, 2022, 13:33 |
writeObjects, internal energy
cbarring
Rep Power: 12 |
Hi All. I am trying to write the internal energy that is calculated in a compressible flow calculation (compressibleInterFoam). Previously, I have written density data using code in controlDict. See this code below.
I want to extract internal energy. Inside the code below, have tried using "e", "thermo:e", etc. Nothing works. Does anybody have any suggestions? Regards ---- Successful code for extracting density data, placed at bottom of controlDict ---- functions { writeObjects1 { type writeObjects; libs ( "libutilityFunctionObjects.so" ); objects ( // list of fields/variables to be written thermo:rho ); writeControl writeTime; writeInterval 1; } } |
February 26, 2022, 20:55 |
Rep Power: 4 |
Maybe I am missing something, but the solver does not solve an energy equation but the temperature equation instead.
However, if the internal energy is indeed calculated by the solver, it would be registered in the object database. To see all the fields available in the database, add a "dummy" variable to the function object. Run the case and check your simulation log at the time step where the function object writes out the fields. You should see an error that "dummy" could not be found and get a list of all the registered objects (and thus the ones available to you). |
February 27, 2022, 18:53 |
cbarring
Rep Power: 12 |
Hi dkaddar: Thanks very much for your reply. This is most useful.
controldict, internal energy, writeobjects |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Internal Energy equation in viscous compressible floe equations | mihirmakwana6 | Main CFD Forum | 8 | August 18, 2015 05:11 |
Decrease of internal energy | Tobard | FLUENT | 6 | July 11, 2011 21:04 |
Internal fan - energy used | pk | FLUENT | 0 | April 22, 2008 07:01 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
