February 19, 2022, 19:07 |
simple flow through a pipe tutorial?
Randy Heiland
So far I've not been able to find a simple tutorial/example of flow through a pipe, e.g., just a straight cylinder. Am I overlooking something obvious? I have the following available after my installation:
FOAM_TUTORIALS=/home/heiland/OpenFOAM/OpenFOAM-9/tutorials heiland@asus:~/OpenFOAM/heiland-9/run$ ls $FOAM_TUTORIALS Allclean basic discreteMethods financial lagrangian resources Allrun combustion DNS heatTransfer mesh stressAnalysis Alltest compressible electromagnetics incompressible multiphase $ ls $FOAM_TUTORIALS/incompressible/ adjointShapeOptimisationFoam icoFoam pimpleFoam porousSimpleFoam simpleFoam SRFSimpleFoam boundaryFoam nonNewtonianIcoFoam pisoFoam shallowWaterFoam SRFPimpleFoam thanks, Randy Related, but not to confuse the simple question above, I also cloned this repo: https://develop.openfoam.com/Development/openfoam.git because it seemed to contain more examples. However, I seem to have a problem when I try to run one of those, e.g.: heiland@asus:~/git/openfoam/tutorials/mesh/blockMesh/pipe$ ./Allrun Running blockMesh on /home/heiland/git/openfoam/tutorials/mesh/blockMesh/pipe heiland@asus:~/git/openfoam/tutorials/mesh/blockMesh/pipe$ ls Allclean Allrun constant log.blockMesh system heiland@asus:~/git/openfoam/tutorials/mesh/blockMesh/pipe$ more log.blockMesh /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9 Exec : blockMesh Date : Feb 19 2022 Time : 19:04:12 Host : "asus" PID : 31250 I/O : uncollated Case : /home/heiland/git/openfoam/tutorials/mesh/blockMesh/pipe nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: wrong token type - expected string, found on line 17 the word 'blockMesh' file: /home/heiland/git/openfoam/tutorials/mesh/blockMesh/pipe/system/controlDict/libs at line 17. From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::fileName&) in file primitives/strings/fileName/fileNameIO.C at line 56. |
flow, pipe, tutorial |
Any pipe (channel) flow tutorial by 'twoPhaseEulerFoam' in version 2.3.0? | mxylondon | OpenFOAM | 4 | June 24, 2015 14:21 |
simple 3D pipe flow diverges with icoFoam | Rol | OpenFOAM | 5 | June 27, 2011 17:02 |
simple pipe flow question | arkur | CFX | 1 | July 11, 2008 16:32 |
some weird results about a simple pipe flow: | Ning | FLUENT | 2 | March 11, 2007 13:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
