Energy not conserved - Air heated up in a sealed room |
February 18, 2022, 10:18 |
Pu Gong
Rep Power: 8 |
Hi everyone,
The case is a sealed room with 80W output heat source. The problem I met is that the total enthalpy increase inside the whole room in 1s is 75J. A buoyantPimpleFoam solver with boussinesq equation of state is used for the case. The setting of the heat source is to use scalarSemiImplicitSource, which used part of the room air as a cellSet heat source. The code is shown as follow Code:
heat1 { type scalarSemiImplicitSource; enabled true; active true; scalarSemiImplicitSourceCoeffs { selectionMode cellSet; cellSet heat1; volumeMode absolute; injectionRateSuSp { h { Su table ( (0 80) ); Sp 0.0; } } } } To measure the enthalpy increase inside the room, a swak4Foam code is used as follow, where 298.15 is the reference temperature T0, 1000 is the mass heat capacity Cp, and vol() is the volume for each cell. Code:
T_volSum_room { name T_volSum_room; type swakExpression; valueType cellSet; libs ("libsimpleSwakFunctionObjects.so" ); outputControlMode timeStep; outputInterval 10; writeStartTime no; setName room; expression "(T-298.15)*1000*vol()*rho"; autoInterpolate true; accumulations (sum); verbose true; } 1. It is due to the boussinesq equation of state. 2. It is caused by the configuration of the heat source, which means the heat source I am using is output less than 80W 3. It is due to the incorrect way of measuring, which means the expression "(T-298.15)*1000*vol()*rho" above cannot measure the enthalpy increase rate properly. Any suggestion would be appreciated Regards Pu |
Air diffusion in room | stteng | OpenFOAM | 1 | December 8, 2021 15:32 |
Simulation of a flow of air in a room from a fan | tejas_jeurkar | FLUENT | 0 | April 4, 2019 11:41 |
Density setting in Fluent for compressed and heated air | bolbol | FLUENT | 4 | May 10, 2018 13:51 |
heat transfer: air in a room and water in a coil | Alberto | CFX | 2 | May 9, 2006 09:56 |
Air movements in the room | Nevill Krik | CFX | 3 | July 28, 2004 18:16 |
