February 15, 2022, 03:49 |
Options to use mapFields in parallel
Rep Power: 10 |
I have some problems to use mapFields with OpenFOAM. I run an analysis with rhoSimpleFoam in parallel and I have both the decomposed and reconstructed simulation at the iteration 7000 (sim01). Now I slightly changed the mesh, I added the boundary layers in some patches but the patches are the same (so mesh is consistent). I'm trying to map the results of sim01 on the new mesh of sim02. But there is a different error on each option of mapFields I try. I can map form and to both the decomposed or reconstructed cases. MapFields seems to work only on the cavity tutorial case.. Here the errors Im getting with the different options. mpirun -np 56 mapFieldsPar ../sim01/ -consistent -sourceTime 7000 -parallelTarget -parallel >logs/mapFields Code:
#0 Foam::error::printStack(Foam::Ostream&)[42] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [45] #0 Foam::error::printStack(Foam::Ostream&)[24] #1 Foam::sigFpe::sigHandler(int)[1] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [42] #1 Foam::sigFpe::sigHandler(int) at ??:? [24] #2 ?[10] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at ??:? [45] #1 Foam::sigFpe::sigHandler(int)[1] #1 Foam::sigFpe::sigHandler(int)[48] #0 Foam::error::printStack(Foam::Ostream&)[12] #0 Foam::error::printStack(Foam::Ostream&) in /lib/x86_64-linux-gnu/libc.so.6 [24] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool)[41] #0 Foam::error::printStack(Foam::Ostream&)[32] #0 Foam::error::printStack(Foam::Ostream&)[46] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at ??:? [42] #2 ? at ??:? [10] #1 Foam::sigFpe::sigHandler(int)[24] #4 Foam::fluidThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&)[29] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [45] #2 ? at ??:? in /lib/x86_64-linux-gnu/libc.so.6 at ??:? [1] #2 ? at ??:? mpirun -np 56 mapFields ../sim01/ -consistent -sourceTime 7000 -paralleSource -parallelTarget -parallel >logs/mapFields or mpirun -np 56 mapFields ../sim01/ -consistent -sourceTime 7000 >logs/mapFields -parallel Code:
Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- ^Cmpirun: abort is already in progress...hit ctrl-c again to forcibly terminate mpirun: Forwarding signal 18 to job [kigen:54076] *** Process received signal *** [kigen:54076] Signal: Segmentation fault (11) [kigen:54076] Signal code: Address not mapped (1) [kigen:54076] Failing at address: 0x30 [kigen:54076] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46520)[0x7f7a3e64d520] [kigen:54076] [ 1] /lib/x86_64-linux-gnu/libpmix.so.2(PMIx_Finalize+0x53d)[0x7f7a3bf1e9ed] [kigen:54076] [ 2] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pmix_ext3x.so(ext3x_client_finalize+0x3aa)[0x7f7a3c097caa] [kigen:54076] [ 3] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_ess_hnp.so(+0x4bb6)[0x7f7a3e416bb6] [kigen:54076] [ 4] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_ess_hnp.so(+0x4c55)[0x7f7a3e416c55] [kigen:54076] [ 5] /lib/x86_64-linux-gnu/libevent_core-2.1.so.7(+0x1cebf)[0x7f7a3e84bebf] [kigen:54076] [ 6] /lib/x86_64-linux-gnu/libevent_core-2.1.so.7(event_base_loop+0x52f)[0x7f7a3e84c75f] [kigen:54076] [ 7] mpirun(+0x128c)[0x5575e827e28c] [kigen:54076] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x2dfd0)[0x7f7a3e634fd0] [kigen:54076] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x7d)[0x7f7a3e63507d] [kigen:54076] [10] mpirun(+0x1425)[0x5575e827e425] [kigen:54076] *** End of error message *** Segmentation fault (core dumped) I succeeded in map the fields using mapFieldsPar in serial as: mapFieldsPar ../sim01/ -consistent -sourceTime 7000 >logs/mapFields but then I get an error when I try to dun the analysis (the setting is the same as sim01) mpirun -np 56 rhoSimpleFoam -parallel Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _14aeaf8dab-20211220 OPENFOAM=2112 version=v2112 Arch : "LSB;label=32;scalar=64" Exec : rhoSimpleFoam -parallel Date : Feb 15 2022 Time : 06:59:10 Host : kigen PID : 52646 I/O : uncollated Case : /home/nablawave/REPO/tccl_repo/sim_09 nProcs : 56 Hosts : ( (kigen 56) ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p_rgh tolerance 0.001 field p tolerance 0.001 field U tolerance 0.0001 field h tolerance 0.0001 field "(k|epsilon|omega)" tolerance 0.0001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } [10] #0 Foam::error::printStack(Foam::Ostream&)[42] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [47] #0 Foam::error::printStack(Foam::Ostream&)[10] #1 Foam::sigFpe::sigHandler(int)[5] #0 Foam::error::printStack(Foam::Ostream&)[4] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [42] #1 Foam::sigFpe::sigHandler(int)[14] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [10] #2 ?[27] #0 Foam::error::printStack(Foam::Ostream&)[19] #0 Foam::error::printStack(Foam::Ostream&) in /lib/x86_64-linux-gnu/libc.so.6 [10] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool)[26] #0 Foam::error::printStack(Foam::Ostream&)[48] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [5] #1 Foam::sigFpe::sigHandler(int)[11] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [20] #0 Foam::error::printStack(Foam::Ostream&)[41] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [42] #2 ?[47] #1 Foam::sigFpe::sigHandler(int) at ??:? [4] #1 Foam::sigFpe::sigHandler(int) at ??:? [10] #4 Foam::fluidThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in /lib/x86_64-linux-gnu/libc.so.6 [42] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool)[31] #0 Foam::error::printStack(Foam::Ostream&)[40] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [14] #1 Foam::sigFpe::sigHandler(int) at ??:? [26] #1 Foam::sigFpe::sigHandler(int) at ??:? [27] #1 Foam::sigFpe::sigHandler(int) at ??:? |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
