problem with source term
Old   February 13, 2022, 17:14
Default problem with source term
manou mouna
Manouu is on a distinguished road
Hello, I want to add a volume force to the momentum equation which depends on the position, so I used fvOptions and codedSource, here is the code I used, I have no errors and the solution converges but the source term is not taken into account, what is the problem in the code please??
regards
PHP Code:
volumicForce
type vectorCodedSource;
active true;
name volumicForce;
vectorCodedSourceCoeffs
selectionMode points;
points
0 0 0)
0 0 0.01)
0 0 0.02)
fields (U);
fieldNames      (U);
codeInclude
codeCorrect
Pout<< "**CorrectCode**" << endl;
codeAddSup
const scalarField&mesh_.V();
vectorFieldFSource eqn.source();
vectorField F(mesh_.nCells(), vector(001)); // declare F
scalarField rho2(mesh_.nCells(), scalar(1000.0)); //declare rho2...
const labelListcellIDs cell();
Info<<"eqn dimension "<<eqn.dimensions()<<nl// to check the dimesnsions
forAll(cellIDsi)
label celli cellIDs[i];
FSource[cellI]-= F[cellI]/rho2[cellI]*V[cellI];
codeSetValue
Pout<< "**codeSetValue**" << endl;
// Dummy entry. Make dependent on above to trigger recompilation
coded
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
volumicForceCoeffs
selectionMode   all;
Manouu is offline   Reply With Quote
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 15:21
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 10:32
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
