February 12, 2022, 05:21 |
rhoSimpleFoam compressible does not converge
Rep Power: 8 |
Hi lovely CFD People,
i'm running a compressible simulation with rhoSimpleFoam but it does not converge. Even worse, the residual of p is really really weird. Anyone happens to know the reason? I basically started with Gauss Upwind to get the stability (but honestly, the p is not stable at all) and switched to Gauss Upwind linear at 100. Iteration. Thx for any answers in advance! |
February 14, 2022, 12:16 |
Julio Pieri
Rep Power: 9 |
Hey! This can be caused by a lot of reasons. Poor mesh would be my first guess, either from low quality elements or by overly coarse mesh. You may also have inconsistent BCs. Lastly, your problem might be so complex that the solver can't find a solution. Breaking it down into chunks of the domain, or gradually accelerate it (actual velocity or thermal stuff) may give you some insights.
Try solving a smaller problem with similar set of properties and BCs to easily debug and test for solutions. |
February 17, 2022, 06:17 |
Not converged
#3 | |
Rep Power: 8 |
Hi Julio,
thanks for your reply! I found out that it was a plotting mistake from me in my gnuplot script. It shoudl look like this one in the attachment. But it is still not satisfying because it didnt converge to my criterien. I changed the schemes step by step during the simulation. Basically from loose to tight. Do you have an idea why the residuals didnt go lower? Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { // default cellMDLimited Gauss linear 0; // super loose // grad(U) cellMDLimited Gauss linear 1; // super loose // default leastSquare; // loose // default cellMDLimited Gauss linear 1; // loose default Gauss linear; // tight grad(U) cellLimited<cubic> 1.5 Gauss linear 1; // in Einsatz ab 1100 Iter. } divSchemes { default none; // div(phi,U) bounded Gauss upwind; // loose div(phi,U) Gauss linearUpwind grad(U); // tight // energy bounded Gauss upwind; // loose energy Gauss linearUpwind default; // tight div(phi,e) $energy; div(phi,h) $energy; div(phi,Ekp) $energy; turbulence Gauss upwind; // turbulence bounded Gauss upwind; // turbulence Gauss linearUpwind default; div(phi,k) $turbulence; div(phi,omega) $turbulence; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; // default Gauss linear corrected; // default Gauss linear limited 0.33; // default Gauss linear limited 0.777; // default Gauss linear orthogonal; // default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; // default limited 0.777; // tight // default limited 0.5; // loose // default limited 0.33; // super loose } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; // loose=1e-5, tight=1e-8 relTol 0.01; // super loose=0.5, tight=0.01 smoother GaussSeidel; nCellsInCoarsestLevel 100; //100 minIter 3; } "(U|k|omega|e)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; // loose=1e-6, tight=1e-8 relTol 0.0; } } SIMPLE // semi-implicit method for pressure-linked euqations { consistent yes; // SIMPLEC formulation for more robust and faster convergence nNonOrthogonalCorrectors 2; // loose=3, tight=2 pMinFactor 0.4; //0.4 pMaxFactor 1.5; //1.5 residualControl { p 1e-8; //eventuell noch kleiner U 1e-7; "(k|omega|e)" 1e-7; } } relaxationFactors { fields { p 0.4; // loose 0.1 rho 0.4; //loose 0.01 } equations { U 0.7; "(k|omega)" 0.7; e 0.7; } } // ************************************************************************* // Quote:
February 17, 2022, 13:46 |
Julio Pieri
Rep Power: 9 |
Hmm, have you tried changing the relaxation factors back to 1 (gradually)? They affect the solution as they can make residuals appear to have stabilized (even if they are oscillating like yours).
The residuals are not the best way to check convergence. It's important to add some physical quantity as well, like force, heat flux, etc. If those have not converged, then your problem really didn't converge. However, if they are stable (and you don't have super low relaxation factors), it might be a stronger indicative you've reached a solution than assessing the residuals. This wiki might also be helpful, though I think you should first tweek your relaxation. https://www.cfd-online.com/Wiki/Ansy...gence_criteria |
February 17, 2022, 14:17 |
forces
#5 | |
Rep Power: 8 |
Hi Julio,
thanks again for you idea. I am still doing some optimising with my mesh. And i will try a new simulation tonight with your advice of changing the relaxation step by step to 1. (My new work station with 16 cores just arrived this afternoon) And this is my force profile, it looks quite stable. Quote:
February 17, 2022, 15:41 |
Julio Pieri
Rep Power: 9 |
Congrats on the workstation!
As for the plot, it seems converged to me. I've seem some rare cases that changing the relax factor would change that profile, though that shouldn't happen. Run the simulation with increased relax factor and post back! |
February 21, 2022, 10:50 |
Michael Alletto
Rep Power: 16 |
Hello, I found that running rhoPimpleFoam with a local Euler sometimes helps to get a steady solution. If there are recirculation regions then it is very hard to get a converged steady solution
compressible, no convergence, rhosimplefoam |
compressible flow calculation error when using rhoSimpleFoam solver | ousoweak | OpenFOAM Running, Solving & CFD | 1 | October 30, 2022 10:00 |
rhoSimpleFoam for sub-sonic compressible aerodynamics. | bentkj | OpenFOAM Running, Solving & CFD | 6 | October 1, 2018 03:18 |
Compressible 2D airfoil rhoSimpleFoam fatal error volScalarField none | jfournier | OpenFOAM Running, Solving & CFD | 4 | September 28, 2017 06:28 |
compressible, rhoSimpleFoam, multi-species, steady state, rocket nozzle | David_C | OpenFOAM Running, Solving & CFD | 1 | April 18, 2017 11:01 |
how is rhoSimpleFoam a compressible steady statefor compressible flow | cleoo | OpenFOAM Pre-Processing | 2 | September 22, 2016 03:23 |
