How to transform the transport equation like this in OpenFOAM?
Old   February 12, 2022, 03:44
Default How to transform the transport equation like this in OpenFOAM?
Jianfeng
jennyjian is on a distinguished road
Hi guys!
I am working on a scalar transport equation in OpenFOAM, which is a little bit complex to make it converge. The equation is attached in the attachment equation 1:
where alpha, Df, Db, Hb have constant values in the whole fluid domain, while pO2 is the unknown oxygen partial pressure and SO2 is a function of pO2.
Firstly, without any treatment, the terms with Hb SO2 are treated as source terms:
The code is
fvm::div(phi,pO2) - fvm::laplacian(Df,pO2) ==
- fvc::SuSp(Hb/alpha*fvc::div(phi,SO2)/pO2,pO2)
+ fvc::Su(1/alpha*fvc::laplacian(Db,SO2))
Since the term Hb/alpha*fvc::div(phi,SO2) is about 7 times the value of div(phi,pO2). This solver diverges very quickly.
Later to solve this, I try to transform the term fvc::div(phi, SO2)
div(u) = 0 when the fluid equation converges. (incompressible)
The equation is listed in the attachment (equation2)
The code is
fvm::div(phi,pO2)-1.0/(1+Hb/alpha*inter1)*fvm::laplacian(Df,pO2)
1.0/(1+Hb/alpha*inter1)*fvc::laplacian(Drbc*Hb/alpha,SO2)
inter1 is grad(SO2)/grad(PO2)
To verify this solver, I use the steady flow across the cylinder Re = 5 as a case, where pO2 at the surface of the cylinder is 760 mmHg, and the inflow is 56mmHg.
However, the result (in attachment result and the correct result in literature Re5_full) seems the scalar pO2 is transported to only the first layer meshes near the boundary, which is a sign of convection only, without the diffusion. I wonder if the term 1.0/(1+Hb/alpha*inter1) can't be written outside the fvm::laplacian, is there any idea or suggestion on how to write this equation in OpenFOAM?
Thanks a lot!
jennyjian is offline   Reply With Quote
Old   February 15, 2022, 15:13
Jianfeng
The first figure is uploaded again
equation definition
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Different ways to treat source terms of an additional transport equation in OpenFOAM adib_mohammad OpenFOAM Running, Solving & CFD 14 January 6, 2022 06:18
How can temperature e treated as a passive scalar be used in transport equation? granzer OpenFOAM Running, Solving & CFD 3 June 6, 2021 17:35
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
