the air phase in multiphaseEulerFoam bubble tutorial case doesn't move |
February 9, 2022, 23:44 |
Muhammad Ahyar
Rep Power: 6 |
I was trying to reproduce a multiphaseEulerFoam tutorial case that happened in 2D into 3D. The original case is located at
$FOAM_TUTORIALS/multiphase/multiphaseEulerFoam/RAS/bubblePipe then i modify the case blockMeshDict so the case geometry would be 3D. but when i tried to run the simulation, the air bubble would not move or just concentrated in specify region, represented in this picture below. meanwhile i was expecting an output like this one from bubbleColumn tutorial that located at Code:
$FOAM_TUTORIALS/multiphase/multiphaseEulerFoam/RAS/bubbleColumn and by the way this is my case in there is something wrong with my setup bubble0702.zip What should i revise/change from my case so it simulate the case like the second picture but with three phases?(first is water, second is air1, and third is air3) my goal is to simulate advection of the phase air1 and air2 so it can move in the continuous phase(water). Thanks in advance |
Air ejection results in stationary air bubble | Michael VF | CFX | 3 | June 9, 2021 20:12 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Cavity tutorial case | shinde.gopal | OpenFOAM Running, Solving & CFD | 3 | June 12, 2015 05:50 |
phase names in multiphaseEulerFoam: strange behaviour | kobelak | OpenFOAM Running, Solving & CFD | 0 | May 11, 2015 18:35 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
