twoPhaseEulerFoam mass balance with different boundary conditions |
February 7, 2022, 10:45 |
Rep Power: 17 |
Dear foamers,
I'm struggling with the mass (im)balance of twoPhaseEulerFoam with different boundary conditions. My conclusion is, that there is a mass imbalance when zeroGradient is used as the boundary for p_rgh at the inlet - i.e. it comes more mass out than going in. With fixedFluxPressure at the inlet, everything looks good. In the attached file a test case (a small vertical channel) is included, which can be run with twoPhaseEulerFoam. There are already two logfiles included - one with fixedFluxPressure and one with zeroGradient. From these one can see the mass fluxes at inlet and outlet patches for the phases. There are a lot of discussion about the right / correct / best way to specify the boundary conditions when gravity is considered but I never found statements regarding the imbalance. Could somebody explain this behavior? I first thought of something like a transient effect, but even after 100 s the mass flux of liquid at the outlet is more than 3 times bigger than at the input. Do I miss something or is my mass flux calculation (alphaRhoPhi) wrong? I'm using OpenFOAM v2012 / 2112 but this effect can also be reproduced it with multiphaseEulerFoam (OF 9). Thanks in advance Ulf twoPhaseEulerFoam_checkMassBalance.zip |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
