Error calculating PMV and PPD indexes (thermal comfort) |
February 2, 2022, 06:20 |
#1 | |
Rep Power: 7 |
I am trying to calculate the PMV and PPD indexes in openfoam. I run the tutorial case "hotComfortRoom" and the PMV PPD values were calculated. Then I tried to calculate those values in another simulation starting from an already calculated velocity and temperature fields, therefore I set the simulation only for 1 timestep and I had this error Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::pow4(Foam::Field<double>&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow4<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::functionObjects::comfort::Tcloth(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&, Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:? #6 Foam::functionObjects::comfort::execute() at ??:? #7 Foam::functionObjects::timeControl::execute() at ??:? #8 Foam::functionObjectList::start() at ??:? #9 Foam::Time::run() const at ??:? #10 Foam::Time::loop() at ??:? #11 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" Quote:
Alternatively there is a post-process function to calculate those indexes? |
Thermal Comfort Extension | hafiy | FLUENT | 3 | January 4, 2023 08:43 |
problem with comfort function (PPD PMV) in post-processing | Andrea23 | OpenFOAM Post-Processing | 1 | April 23, 2021 14:55 |
UDF for PMV and PPD | lcbarreto | Fluent UDF and Scheme Programming | 4 | February 7, 2019 07:44 |
PPD & PMV value | Tanty Ali | CFX | 6 | April 3, 2018 06:40 |
HVAC & thermal comfort tools | a_habib | OpenFOAM Running, Solving & CFD | 2 | March 7, 2018 17:42 |
