February 2, 2022, 04:25 |
completely passive particle tracking
Giorgio Negrini
Rep Power: 6 |
Hi all,
I'm trying to perform langrangian particle tracking on a simple case. Basically my flow domain is made by a hollow cylinder where I impose a flow rate at the inlet and a rotation at the internal wall. So my flow rotates and advances in axial direction. Moreover the flow is steady state. I want to perform a completely passive tracking, so where particles follow streamlines. I expect particles to remain at their initial radial coordinate and to move towards the outlet. This does not happen at all. I upload two images: the first is the initial state of the particles and the second is the state at the first time step. Moreover, I initialize the particle velocity with their velocity position in the flow. Thanks in advance! Giorgio PS: this is my kinematicCloudProperties dictionary: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object particleProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled false; transient yes; cellValueSourceCorrection on; calcFrequency 1; maxCo 1; maxTrackTime 10000; interpolationSchemes { rho cell; U cellPoint; mu cell; DUcDt cellPoint; "(.*)" cell; } integrationSchemes { U Euler; } sourceTerms { schemes { U semiImplicit 1; } } } subModels { radiation off; dispersionModel none; collisionModel none; heatTransferModel none; surfaceFilmModel none; stochasticCollisionModel none; patchInteractionModel localInteraction; particleForces { pressureGradient {} } injBase { type initManualInjection; parcelBasisType fixed; massTotal 0; nParticle 1; U0 (0 0 0); SOI 0; sizeDistribution { type fixedValue; fixedValueDistribution { value 1e-13; } } } injectionModels { Cluster0 { $injBase positionsFile "Cluster0Positions"; } } localInteractionCoeffs { patches ( INLET { type escape; } OUTLET { type escape; } INTERNAL { type stick; e 0.97; mu 0.03; } EXTERNAL { type stick; e 0.97; mu 0.03; } ); } } constantProperties { rho0 1; } cloudFunctions {} // ************************************************************************* // |
August 12, 2023, 15:34 |
Giorgio Negrini
Rep Power: 6 |
[swak4Foam] Validation of swak4Foam for lagrangian particle tracking | nero235 | OpenFOAM Community Contributions | 13 | March 28, 2017 05:45 |
Particle tracking | AKHILESH S L | CFX | 1 | November 14, 2013 16:45 |
[OpenFOAM] ParaView ErrOr | soheil nazmdeh | ParaView | 1 | August 17, 2013 07:40 |
particle tracking in unsteady flow | peterchen | FLUENT | 1 | July 22, 2010 22:18 |
particle tracking | Gab | CFX | 0 | January 5, 2006 16:12 |
