fireFoam/reactingFoam with ISAT results in processor heat up
Old   February 1, 2022, 12:48
Default fireFoam/reactingFoam with ISAT results in processor heat up
Jeff
jfg5067 is on a distinguished road
I have been testing fireFoam & reactingFoam for use with ISAT (TDAC with no reduction) on a uniformly resolved, static mesh based on the smallPoolFire2D tutorial and noticed that the data on one processor heats up differently than all the others. I have also tried performing these runs in serial, where the entire domain heats up accordingly (unphysical for the entire domain to instantly heat up). I have included a screenshot of what this looks like. The following details are the differences from the tutorial:
- 2mm resolution
- laminar combustion and turbulence model
- GRI mech 3.0 + TDAC (only tabulated chemistry - ISAT)
I have ran this in OF7, OF9, OFdev and v2012, with fireFoam (buoyantReactingFoam) and reactingFoam - both show the same result. However, when I turn TDAC off, all 4 trials work fine. I have attached my chemistryProperties file from an OF7 run.
More than happy to also upload the full case for anyone willing to take a gander.
jfg5067 is offline   Reply With Quote
Old   February 2, 2022, 09:51
Jeff
issue ended up being ISAT tolerance too low (3e-3 moved to 3e-6), although I am still at a bit of a loss why the lower tolerance on the tabulation accuracy led to one processor deviating in solution from the others so significantly
chemistry, firefoam, isat, reactingfoam, tdac
Time sensitivity analysis - results variation qntldoql FLUENT 1 January 25, 2022 01:07
My results become inconsistent when using PIMPLE (nOuterCorrectors>1) instead of PISO FloB OpenFOAM Running, Solving & CFD 5 May 17, 2021 07:17
lid driven cavity varying results yasmil OpenFOAM Running, Solving & CFD 2 October 6, 2016 22:42
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 09:54
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 19:47
