Solving a Two Phase Flow (nanofluid) through a tube |
Amal Chummar
Rep Power: 5 ![]() |
Hello
I am a new openFOAM user. I would like to know whether it is possible to solve the turbulent (Re = 25000) heat transfer of a nanofluid (Al2O3 + water) considering it as a two phase flow through a horizontally placed thick circular tube (20 mm radius with pipe thickness as 10 mm) of iron material which is getting heated from the bottom. It is to analyze the conjugate heat transfer ( conduction + convection ). I am trying to use various turbulent models ( mixture model, k-ephsilon model) to compare the results like contours of temperature as well as velocity and their corresponding plots with various Re numbers. Also I am planning on varying the volume concentration (0 to 3%) of the nanofluid and obtain various results. Is this possible to do in openFOAM and which solvers will i have to use. ![]() |
conjugate heat transfer, nanofluid modelling, turbulent channel flow, two phase model |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
