interFoam simulation crashing after ~3000 timesteps
Old   January 30, 2022, 01:58
Default interFoam simulation crashing after ~3000 timesteps
Gino Parisella
ginop is on a distinguished road
I am a bit puzzled with this case, and need your opinion.
Here, I am running a transient, incompressible multi-phase simulation with interFoam (v2012). I've already run the same geometry/mesh under different conditions, with success.
I suspect that the issue may be due to the mesh, though the same grid worked under a different oscillation frequency (same amplitude)
This particular case crashes after many timesteps, about 3000. The case is dynamic, using
angularOscillatingDisplacement
Attached is an extract of my log file, including a few timesteps before crashing.
My finite volume files are included below.
Any help is much appreciated.
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    div(rhoPhi,U)   Gauss linearUpwindV grad(U); //Gauss vanLeerV;
    div(phi,U)      Gauss linearUpwindV grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss vanLeer; //interfaceCompression;
    div(phi,k)      bounded Gauss linearUpwind  grad(k);
    div(phi,omega)  bounded Gauss linearUpwind  grad(omega);
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
        method meshWave;
fvSolution
solvers
    "alpha.water.*"
        nAlphaCorr      3;
        nAlphaSubCycles 1;
        cAlpha          1;
        icAlpha         0;
        MULESCorr       yes;
        nLimiterIter    15;
        alphaApplyPrevCorr  yes;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-10;
        relTol          0;
        minIter         1;
    "pcorr.*"
        solver          GAMG;
        smoother        DIC;
        tolerance       1e-05;
        relTol          0;
    p_rgh
        solver          GAMG;
        smoother        DICGaussSeidel;
        tolerance       1e-09;
        relTol          0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|k|omega)"
        smoother        DILUGaussSeidel;
        tolerance       1e-06;
        relTol          0.01;
        minIter         1;
        maxIter         20;
    "(U|k|omega)Final"
        smoother        GaussSeidel;
        tolerance       1e-08;
        relTol          0;
        maxIter         50;
    "cellDisplacement.*"
        solver          GAMG;
        tolerance       1e-8;
        relTol          0;
    Phi
        tolerance       1e-08;
        relTol          0;
potentialFlow
    nNonOrthogonalCorrectors 10;
    PhiRefCell 0;
    PhiRefValue 0;
PIMPLE
    nNonOrthogonalCorrectors 2;
    nCorrectors         1;
    nOuterCorrectors    25;
    correctPhi          true;
    moveMeshOuterCorrectors true;
    turbOnFinalIterOnly yes;
    pRefCell            0;
    pRefValue           0;
    residualControl
        U
            tolerance  1e-4;
            relTol      0;
        p_rgh
            tolerance  1e-5;
            relTol      0;
relaxationFactors
    fields
        p_rgh       0.5;
        p_rghFinal  1;
    equations
        ".*"        1;
        U           0.7;
        UFinal      1;
cache
    grad(U);
ginop is offline   Reply With Quote
How to tell the solver to stop simulation after a specific number of timesteps? MCrossover97 OpenFOAM Running, Solving & CFD 1 October 24, 2021 14:43
interFoam, high velocity's and decreasing timestep's Kahnbein.Kai OpenFOAM Running, Solving & CFD 4 August 24, 2021 15:35
interFoam - sudden simulation crash fmerk OpenFOAM Running, Solving & CFD 3 October 25, 2017 04:13
Simulation of drop with interFoam abdessamad OpenFOAM Running, Solving & CFD 7 April 29, 2014 20:28
steady state simulation timesteps amine CFX 4 March 17, 2008 11:29
