January 29, 2022, 07:09 |
porosityProperties in 3D
Teh Tiong Wei
Rep Power: 5 |
Hi all,
I am trying to define several 3d-porous zones in my mesh. I based my case on the angled duct tutorial. My issue is that I added an e3 coordinate for my z-coordinate (the angled Duct tutorial has only e1 and e2), thinking that OpenFOAM will automatically detect that this should be a 3d case. Here is my porosity Properties: HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object porosityProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // porosity1 { type DarcyForchheimer; cellZone insideZone1; d (5e10 5e10 5e10); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } porosity2 { type DarcyForchheimer; cellZone insideZone2; d (5e10 5e10 5e10); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } porosity3 { type DarcyForchheimer; cellZone insideZone3; d (5e10 5e10 5e10); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } // ************************************************************************* // HTML Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : porousSimpleFoam Date : Jan 29 2022 Time : 11:56:44 Host : MSI PID : 1462 I/O : uncollated Case : /home/wei/OpenFOAM_files/work_ICVT/yarn1 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 100 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: insideZone1 origin: (0 0 0) e1: (1 0 0) e2: (0 1 0) local bounds: (14.16092 31.72034 10.04544) Porosity region porosity2: selecting model: DarcyForchheimer creating porous zone: insideZone2 origin: (0 0 0) e1: (1 0 0) e2: (0 1 0) local bounds: (14.14524 31.72034 10.05064) Porosity region porosity3: selecting model: DarcyForchheimer creating porous zone: insideZone3 origin: (0 0 0) e1: (1 0 0) e2: (0 1 0) local bounds: (28.40675 24.12406 9.895435) Using pressure implicit porosity Starting time loop Time = 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.02127579, No Iterations 6 time step continuity errors : sum local = 6.154702e-05, global = -1.226986e-05, cumulative = -1.226986e-05 smoothSolver: Solving for epsilon, Initial residual = 0.9990214, Final residual = 7.133068e-09, No Iterations 2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 4.369756e-06, No Iterations 2 ExecutionTime = 5.16 s ClockTime = 5 s ... Thanks a lot in advance! |
January 31, 2022, 04:36 |
Yann
Rep Power: 29 |
Your porous zone is already 3D. The coordinate system is defined as an orthonormal basis, hence you only need to define the origin and 2 vector axis, as the 3rd one will be automatically created based on the 2 other vectors. This is why only the 2 first vectors are used by the solver when creating the porous zones. You only have to define 2 of the 3 vectors, but you can define any of them (e.g. e1+e2, or e1+e3, etc...) Cheers, Yann |
porosity model, porosity properties |
