Error: Cannot find patchField entry
Old   January 28, 2022, 09:53
Default Error: Cannot find patchField entry
Oliver Meng is on a distinguished road
i'm trying to run a 3D simulation with meshing with snappyHexMesh. In order to get a better wall meshing, i have define a plate to refine this surface.
But as i run the solver, it told me that it cannot find the patchField "plate" (which i named in the snappyHexMeshDict).
So the question is: do i need to define a BC for the "plate"?
--> FOAM FATAL IO ERROR: (openfoam-2106 patch=211215)
[1] Cannot find patchField entry for plate
[1]
[1] file: /home/nmeng/Schreibtisch/pod/processor1/0/p.boundaryField at line 11 to 50.
[1]
[1] From void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
[1] in file /builddir/build/BUILD/OpenFOAM-v2106/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 172.
[1]
FOAM parallel run exiting
Oliver Meng is offline   Reply With Quote
[snappyHexMesh] Cannot find patchField entry for *** mbox97 OpenFOAM Meshing & Mesh Conversion 2 November 25, 2021 11:06
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 22:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 18:22
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
