[swak4foam] Cannot run the case in using overset mesh
Old   January 25, 2022, 05:02
Unhappy [swak4foam] Cannot run the case in using overset mesh
Nghiep
Nghiep is on a distinguished road
Dear All,
Currently, I am running the case with a combination swak4foam and overset mesh. I have successfully compiled the swak4foam in OpenFOAM ESI v2106. When I run the case using Valve Field to control the "groovyCyclicACMI" patch, I cannot run because of the below errors
--> FOAM FATAL ERROR: (openfoam-2106)
request for volScalarField valveField from objectRegistry region0 failed
available objects of type volScalarField are
0()
From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
in file /opt/OpenFOAM-v2106/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 463.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::exitOrAbort(int, bool) at ??:?
#2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&, bool) const at ??:?
#3 Foam::groovyCyclicACMIPolyPatch::resetAMI() const at ??:?
#4 Foam::cyclicACMIPolyPatch::initGeometry(Foam::Pstr eamBuffers&) at ??:?
#5 Foam::polyBoundaryMesh::calcGeometry() at ??:?
#6 Foam::polyMesh::addPatches(Foam::PtrList<Foam::pol yPatch>&, bool) at ??:?
#7 Foam::fvMesh::addFvPatches(Foam::PtrList<Foam::pol yPatch>&, bool) at ??:?
#8 Foam::fvMesh::addFvPatches(Foam::List<Foam::polyPa tch*> const&, bool) at ??:?
#9 Foam::fvMeshSubset::setCellSubset(Foam::bitSet const&, int, bool) at ??:?
#10 Foam::fvMeshSubset::setCellSubset(int, Foam::UList<int> const&, int, bool) at ??:?
#11 Foam::fvMeshSubset::fvMeshSubset(Foam::fvMesh const&, int, Foam::UList<int> const&, int, bool) at ??:?
#12 Foam::cellCellStencils::cellVolumeWeight::update() at ??:?
#13 Foam::cellCellStencils::cellVolumeWeight::cellVolu meWeight(Foam::fvMesh const&, Foam::dictionary const&, bool) at ??:?
#14 Foam::cellCellStencil::addmeshConstructorToTable<F oam::cellCellStencils::cellVolumeWeight>::New(Foam ::fvMesh const&, Foam::dictionary const&, bool) at ??:?
#15 Foam::cellCellStencil::New(Foam::fvMesh const&, Foam::dictionary const&, bool) at ??:?
#16 Foam::cellCellStencilObject const& Foam::MeshObject<Foam::fvMesh, Foam::MoveableMeshObject, Foam::cellCellStencilObject>::New<>(Foam::fvMesh const&) in /opt/OpenFOAM-v2106/platforms/linux64GccDPInt32Opt/bin/overPimpleDyMFoam
#17 ? in /opt/OpenFOAM-v2106/platforms/linux64GccDPInt32Opt/bin/overPimpleDyMFoam
#18 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#19 ? in /opt/OpenFOAM-v2106/platforms/linux64GccDPInt32Opt/bin/overPimpleDyMFoam
Aborted (core dumped)
Has anyone solved this problem before? Please give me an idea of how to fix it. Thank you in advance
Nghiep is offline   Reply With Quote
Overset 3D mesh case crash at start quarkz OpenFOAM Running, Solving & CFD 0 December 11, 2020 20:44
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
mesh generation and case run in parallel with different solver burt OpenFOAM 0 December 7, 2012 02:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
