January 23, 2022, 15:23 |
running openFOAM9 via FreeCAD
sam j
Rep Power: 4 |
Two particular commands needs to be part of Allrun script especially if flow problem solved in multiprocessors.
reconstructPar -newTimes This command writes results into corresponding time stamps otherwise what you will have 0/ Another command also necessarily be part of Allrun script is simppleFoam -postProcess -func wallShearStress This will calculate wallShearStress at the wall (no-slip) BC. This you will U, p and wallShearStress variables available to plot in Paraview. I literally wasted 4 weeks figuring out this for a novice. |
freecad, openfoam, paraview |
Simulation just stops output writing, but keeps running | blaise | OpenFOAM Running, Solving & CFD | 6 | March 27, 2024 04:49 |
Running Case in Parallel | Typ | Main CFD Forum | 5 | May 11, 2020 03:43 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Error problem while running sadia d lts tutorial | kane | OpenFOAM Running, Solving & CFD | 2 | May 26, 2018 03:38 |
Error Running Design of Experiments in ANSYS Fluent | tytrzecki | FLUENT | 0 | April 22, 2018 15:01 |
