Time varying external torque on rigid body
Old   January 21, 2022, 06:40
Question Time varying external torque on rigid body
Adrian del Ser
adrian.delser is on a distinguished road
Hello, I'm trying to run a 2D simulation of a thin flat plate in a single phase fluid (such as air). The plate will start with a certain velocity in the x direction and its motion will be affected by fluid forces acting on it (this part can probably be done with the rigidBodyMotion library and looking at the floatingObject tutorial).
I'd like to control the pitch of the flat plate as it moves through the flow by applying a time dependent external torque, which would combine with the pressure forces to affect the motion of the plate. This torque is not known in advance, and will be calculated with feedback from the current state of the simulation. How could this be achieved in practice? The goal is to be able to have some control over the motion of the plate through time.
An alternative would be to control the rotational speed of the airfoil through time, but I'm not sure how to go about this either.
Thanks,
Adrian
adrian.delser is offline   Reply With Quote
body forces, rigidbodymotion, sixdofrigidbodymotion
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
pimpleDyMFoam with sixDoFRigidBodyMotionCoeffs: External Torque chaz OpenFOAM Running, Solving & CFD 0 May 7, 2017 20:22
Time step based on rigid body velocity Omran CFX 1 May 31, 2015 20:27
