Missing of points Files
Old   January 21, 2022, 02:17
Default Missing of points Files
Ram kumar
Ram Kumar is on a distinguished road
I am new to OpenFoam. I had successfully installed the pdfFoam in OpenFOAM-2.1.x. I tried to run the default SandiaD case given in the tutorial of pdfFoam. The simulation is not running because some files are missing (SandiaD/constant/boundaryData/jet/points). Please have a look. I am positively looking for your valuable inputs.
--> FOAM FATAL IO ERROR:
cannot find file
file: SandiaD/constant/boundaryData/jet/points at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Ram Kumar is offline   Reply With Quote
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Monitor Files Missing Forrest FLUENT 3 March 24, 2009 17:11
