water injection error
Old   January 21, 2022, 01:45
Default water injection error
wjchoi is on a distinguished road
hello i am a beginner of openfoam !
To run the weiroverflow example related to water injection, i modified some parts of original weiroverflow tutorial code. so i made 2(m) * 2(m) square geometry (2D analysis), and set the left edge as inlet, bottom and right edge as walls, top edge as atmosphere. and i want to time varying water injection, so i modified the alpha.water and velocity (U) boundary condition of "inlet" in original code.
modified contents about inlet are below
[alpha water]
boundaryField
inlet1
type variableHeightFlowRate;
lowerBound 0;
upperBound 1;
value uniform 0;
[U]
boundaryField
inlet1
type variableHeightFlowRateInletVelocity;
alpha alpha.water;
value uniform (0 0 0);
flowRate table
(0 0)
(100 0)
(100.01 0.0005)
(200 0.0005)
(200.01 0)
(300 0)
(300.01 0.0005)
(400 0.0005)
(400.01 0)
(500 0)
(500.01 0.0005)
(600 0.0005)
(600.01 0)
(700 0)
(700.01 0.0005)
(800 0.0005)
(800.01 0)
(900 0)
(900.01 0.0005)
(1000 0.0005)
this worked well !
so to go one step further, in this time, i set the inlet as parts of left edge not all left edge.
Unlike setting the entire left edge (2m) as the inlet condition in my previous code, i only set parts of left edge as inlet (coordinate (-1 0.5 0) ~ (-1 0.9 0) ; inlet length 0.4m), and the others of left edge except inlet are walls
and all condition except this condition are same as previous code.. (vertices of whole square geometry that i used are (-1 -1 0) (-1 1 0) (1 1 0) (1 -1 0))
however in this case, the error occurs.. the contents of error are below.
[error]
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.05 Min(alpha.water) = 0 Max(alpha.water) = 1
[32] #0 Foam::error:rintStack(Foam::Ostream&)[33] #0 Foam::error:rintStack(Foam::Ostream&)[36] #0 Foam::error:rintStack(Foam::Ostream&)[38] #0 Foam::error:rintStack(Foam::Ostream&)[39] #0 Foam::error:rintStack(Foam::Ostream&)[41] #0 Foam::error:rintStack(Foam::Ostream&)[45] #0 Foam::error:rintStack(Foam::Ostream&)[47] #0 Foam::error:rintStack(Foam::Ostream&)[51] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0
(omitted)
[28] #1 Foam::sigFpe::sigHandler(int) at ??:?
at ??:?
[14] #1 Foam::sigFpe::sigHandler(int)[39] #1 Foam::sigFpe::sigHandler(int) at ??:?
[33] #1 Foam::sigFpe::sigHandler(int)[26] #1 Foam::sigFpe::sigHandler(int) at ??:?
[43] #1 Foam::sigFpe::sigHandler(int) at ??:?
[15] #1 Foam::sigFpe::sigHandler(int) at ??:?
at ??:?
[6] #1 Foam::sigFpe::sigHandler(int) at ??:?
[55] #1 Foam::sigFpe::sigHandler(int)[20] #1 Foam::sigFpe::sigHandler(int) at ??:?
at ??:?
at ??:?
[9] #1 Foam::sigFpe::sigHandler(int) at ??:?
(omitted)
i didn't understant this error..
can someone tell me what should i do for solving this problem..?
thank you !!
wjchoi is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
