pUCoupledFoam applied to industrial cases?
Old   January 17, 2022, 21:22
Default pUCoupledFoam applied to industrial cases?
Ruiyan Chen
cryabroad is on a distinguished road
Hello Foamers,
I wonder if anyone have used the pUCoupledFoam solver from foam-extend. First I did the tutorials and found that indeed it allows you to get convergence much faster (in terms of the total number of iterations, each iteration costs more resources, as expected). Then I applied it to the Askervein Hill case, which many consider to be a benchmark test case for flow over complex terrains. However, the case diverges really fast. I tried several boundary conditions and numerical schemes, but no success.
Also, I tried "coupled" solver in Fluent, and by default it activates the "pseudo transient" temporal scheme, which also helps to get faster convergence and higher stability for steady-state cases. Could this be the key?
Thanks in advance.
Ruiyan
cryabroad is offline   Reply With Quote
Old   January 19, 2022, 04:30
Ruiyan Chen
Anyone tried pUCoupledFoam, especially on industrial cases?
running multiple parallel cases in openfoam slows the simulation kkpal OpenFOAM Running, Solving & CFD 2 August 21, 2015 12:08
Comparing cases in CFD-post : Using scalar speed swaldman CFX 2 April 11, 2014 12:12
Is OpenFOAM tutorial cases valid? j-avdeev OpenFOAM Running, Solving & CFD 3 September 19, 2012 16:45
Applied Industrial Fluid Dynamics course Lasse Rosendahl Main CFD Forum 0 April 5, 2001 05:08
Applied Industrial Fluid Dynamics course symposium Lasse Rosendahl Main CFD Forum 0 February 16, 2001 09:09
