buoyantReactingFoam: writing the total radiative heat flux field |
January 12, 2022, 05:49 |
Rep Power: 10 |
Hi
I'm running a simulation with buoyantReactingFoam (openfoam 9) using fvDOM as the radiation model. I would like to print the total radiative heat flux qr at each write time. qr is defined as: Code:
qr_ ( IOobject ( "qr", mesh_.time().timeName(), mesh_, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh_, dimensionedScalar(dimMass/pow3(dimTime), 0) ), I tried to request writing it by defining the following function object in my controlDict: Code:
functions { writeQr { type writeObjects; functionObjectLibs ( "libutilityFunctionObjects.so" ); objects ("qr"); writeControl writeTime; } } Code:
--> FOAM Warning : writeObjects: object qr not found in database. Available objects: 75 ( CH4 CH4Mean CH4_0 CO2 CO2_0 Cp Cv GAMGAgglomeration H2O H2OMean H2O_0 K K_0 MRFProperties N2 O2 O2Mean O2_0 Residuals<scalar> Residuals<vector> T TMean U UMean U_0 alphat boundary cellZones combustionProperties data delta dpdt faceZones faces fres_CH4 fres_CO2 fres_H2O fres_N2 fres_O2 fvConstraints fvModels fvSchemes fvSolution g gh ghf h hRef h_0 k k_0 momentumTransport neighbour nut owner p pRef p_0 p_rgh p_rgh_0 ph_rgh phi phi_0 pointZones points rho rho_0 solutionControl thermo:alpha thermo:mu thermo:psi thermo:psi_0 thermophysicalProperties thermophysicalTransport wFuel ) Thanks so much |
January 12, 2022, 08:52 |
Rep Power: 10 |
I didn't set fvModels up correctly so that I had no radiation. qr is written by default. No need for a function object.
fvdom |
Simulating constant heat flux value at solid-solid boundary | Y27 | STAR-CCM+ | 6 | September 8, 2020 10:56 |
How to assign convective and radiative heat flux separately? | vs1 | OpenFOAM Running, Solving & CFD | 0 | July 18, 2018 09:11 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
