[OpenFOAM] Unable to obtain samples at specified writeInterval |
Nishant
Rep Power: 15 ![]() |
Hello all. I am trying to obtain values of pressure and velocity at certain time interval but the output time directories are not created at the specified writeInterval.
Here is the controlDict that I am using (based on the motorBike tutorial): Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleRASModels.so" ); application simpleFoam; startTime 0; stopAt endTime; endTime 100; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 1; writeFormat binary; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable true; functions { internalField { type sets; libs ("libsampling.so"); enabled true; interpolationScheme cellPoint; setFormat raw; writeControl adjustableRunTime; writeInterval 20; timeStart 20; timeEnd 80; fields ( p U ); points ( #include "pointCloud.dat" // List of xyz coordinates ); sets ( cloud { type cloud; axis xyz; points $points; } ); } } // ************************************************************************* // Code:
>> ls postProcessing/internalField/ 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 100 This behavior remains the same for different values of writeInterval, timeStart and timeEnd that I played with. How can I obtain the data only at the time periods defined by the writeInterval, that is at time steps 20,40,60... ? |
Nishant
The issue is resolved by modifying the sampling function as:
outputControl adjustableRunTime; outputInterval 20; |
controldict, openfoam, point cloud, sampling, writeinterval |
Unable to obtain the actual velocity profile of a sinusoidal udf | Gourabc | FLUENT | 0 | March 4, 2017 04:49 |
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 09:18 |
unable to obtain residual and lift coefficient convergence in SU2 | deeps | SU2 | 3 | December 27, 2013 01:58 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
