Negative pressure in wave structure simulation |
January 10, 2022, 03:47 |
Haoran Zhou
Rep Power: 7 |
Hi all,
I'm doing wave structure simulation using OpenFOAM. I extracted pressure time series of several monitoring points on the structure and found one of the time series had some negative pressure. I did another simulation with refined mesh to perform mesh convergence check and found some of the negative pressure disappear. Can I come to the conclusion that the previous negative pressure are due to the nonconvergence? And the left negative pressure are caused by wave retreating? |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 19:10 |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 02:33 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 21:05 |
why doesn't ansys allow a negative pressure when cavitation is included | vysje | CFX | 16 | December 11, 2016 18:18 |
Negative Pressure in H2 gas flow and other physical interrogation | FloMol | ANSYS | 2 | April 9, 2012 20:57 |
