Transonic and compressible case with chtMultiRegion-Solver
Old   January 3, 2022, 09:10
Default Transonic and compressible case with chtMultiRegion-Solver
erebos23 is on a distinguished road
Hello all,
I would like to analyze the cooling of a plunger in a steady-state simulation. The plunger is cooled by air. The air enters the system at 4.5 bar (absolute pressure) and leaves at atmospheric pressure. On the outside of the plunger, a heat flow is specified that increases linearly from the top to the bottom of the plunger.
The attached picture shows a quarter of the geometry. The air flows into the system from the right, leaves the cooling tube via the small cooling holes. Then flows along between the cooling tube and the plunger and leaves the system again via the larger holes.
The mesh was created with Salome and checkMesh shows that this is OK. I would like to compare my results with similar simulations done with Ansys. In both cases tetrahedral meshes are/were used.
My problem is that the solution does not converge, but terminates prematurely due to negative temperatures. I have uploaded my case at the following link: https://www.dropbox.com/sh/pkq7ketpc...QbAeYKJAa?dl=0
Reducing the relaxation factors does lead to a slight improvement in the convergence behavior, but the simulation terminates here as well.
What else could I test out to get the simulation to work?
Thanks a lot for your help in advance.
With kind regards
erebos23
erebos23 is offline   Reply With Quote
Old   January 4, 2022, 16:34
I have checked my boundary conditions once with a compressible fluid, here the calculation also runs quite normally. However, when I switch to a compressible fluid, the simulation stops after a certain time at a pressure difference of 0.15 bar due to negative temperatures.
Do I probably have a mistake in the definition of the boundary conditions? I use the following boundary conditions for the fluid:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/fluid";
    object      p;
dimensions      [ 1 -1 -2 0 0 0 0 ];
internalField   uniform 95000;
boundaryField
     inlet
            type              calculated;
            value        $internalField;
       outlet
            type              calculated;
       sym_fluid
            type              symmetry;
       fluid_to_solid
            type              calculated;
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      p_rgh;
internalField   uniform 100000;
boundaryField
        inlet
                type            prghTotalPressure;
                p0              uniform 110000;
                value         uniform 110000;
        outlet
                type          prghPressure;
                p               uniform 95000;
                value        uniform 95000;
       sym_fluid
               type        symmetry;
       fluid_to_solid
                type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0/fluid";
    object      U;
dimensions      [ 0 1 -1 0 0 0 0 ];
internalField   uniform (0 0 0);
boundaryField
        inlet
            type            pressureInletVelocity;
        outlet
            type            pressureInletOutletVelocity;
       sym_fluid
           type        symmetry;
       fluid_to_solid
            type              noSlip;
Or should I change something in my solver settings? Here I use the following settings for fvSchemes and fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default             none;
    div(phi,U)          bounded Gauss upwind;
    energy              bounded Gauss upwind;
    div(phi,K)          $energy;
    div(phi,h)          $energy;
    turbulence          bounded Gauss upwind;
    div(phi,k)          $turbulence;
    div(phi,epsilon)     $turbulence;
    div(phi,R)          $turbulence;
    div(R)              Gauss linear;
    div(Ji,Ii_h)        Gauss linearUpwind grad(U);
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-6;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.01;
        smoother         GaussSeidel;
    "(U|h|k|epsilon|G|Ii)"
        solver           PBiCGStab;
        preconditioner   DILU;
        tolerance        1e-6;
        relTol           0.1;
SIMPLE
    momentumPredictor yes;
    nNonOrthogonalCorrectors 1;
    rhoMin          0.2;
    rhoMax        10;
relaxationFactors
    fields
        rho             0.1;
        p_rgh           0.1;
    equations
        U               0.1;
        h               0.1;
        "(k|epsilon|omega)" 0.1;
Or should I test the komegaSST turbulence model instead of kepsilon?
Thanks for your help in advance.
Best regards.
erebos23
Old   April 30, 2024, 01:27
Default Maybe the problem is with the mesh
subhkaran singh
barbarian_subhkaran is on a distinguished road
I suffered from the same problem, with negative temperatures, while using rhoCentralFoam for supersonic flows. The answer was either a too-coarse or a too fine mesh. Find an optimized mesh resolution and try again.
barbarian_subhkaran is offline   Reply With Quote
chtmultiregionsimpefoam, compressible air, transonic flow
Compressible nozzle flow - no problem for fluent but impossible with openFOAM? flar.t OpenFOAM Running, Solving & CFD 10 March 30, 2022 02:21
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Periodic Compressible (subsonic, transonic) channel flow case setup backscatter OpenFOAM Running, Solving & CFD 0 August 27, 2018 18:39
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 11:47
Compressible transonic airfoil RAE2822 simulation Stefano Siemens 9 June 21, 2006 11:47
