multiphaseEulerFoam- BC's
Old   January 2, 2022, 17:26
Default multiphaseEulerFoam- BC's
qutadah
qutadah.r is on a distinguished road
Hello everyone,
I have a setup case running multiphase simulations, and i just changed the polyMesh to a new one, and I cannot start the simulation apparently to poor or wrong BC setup.... Can you guys help? Which BC's are necessary? I have used the pre-setup case as a base and defined all of the necessary files, there is however one thing i cant do, I have a file Co(phi,air) which is nonuniformly defined as binary file, is that file necessary to be there? or can i just delete it? and can someone advise how to define a uniform field one if it is indeed necessary to keep it?
Thanks!
P.S: checkMesh: Mesh OK.
qutadah.r is offline   Reply With Quote
multiphaseeulerfoam, openfoam9
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 19, 2023 00:49
[ANSYS Meshing] Wing leading edge curvature meshing problem Alexia166 ANSYS Meshing & Geometry 2 April 21, 2021 05:29
[ICEM] ICEM CFD volume meshing problem PietW ANSYS Meshing & Geometry 5 September 15, 2020 05:19
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
