automap and rmap in OpenFOAM boundaries
Old   December 24, 2021, 08:52
Default automap and rmap in OpenFOAM boundaries
trailer is on a distinguished road
Hello to all,
I have tried to get information on the automap and rmap function in OF to no avail.
I see that boundaries that create fields use them (e.g., prghPressure, totalPressure, totalTemperature) while others do not e.g., swirlFanVelocity/fixedMean/flowRateInletVelocity (although fields are created in the calculation)
I would like to know, what they are used for and when do I need to define them. Do they impact the calculations?
rmap appears to be used when reconstructing the fields, automap I do not know.
PS: Sorry for putting the post here. It should be in the programming session
trailer is offline   Reply With Quote
Old   December 25, 2021, 14:23
Hrvoje Jasak
They are needed for decomposePar, reconstructPar, topological changes and load balancing: in fact every time the mesh dynamically changes during the run.
One of mine,
Hrv
Hrvoje Jasak
Old   December 25, 2021, 16:49
Hello prof. Jasak,
Thank you for the reply.
If you would be so kind, a follow up question.
If one is writing a Dirichlet boundary condition for a static case without collecting field (scalar, vector and tensor) information from the variable files, the default (in fvPatchField) automap and rmap can be used, which is why there is no redefinition of automap and rmap in e.g., parabolicVelocity.
Is this correct?
Can you give me a tutorial example where the automap function is being used?
Old   March 27, 2023, 02:13
Xiangjie Wang
XJ_Wang is on a distinguished road
Originally Posted by trailer View Post
Hello prof. Jasak,
Is this correct?
Hi Trailer
Have you found some references for this?
Best
Xiangjie
XJ_Wang is offline   Reply With Quote
Old   March 28, 2023, 05:08
Originally Posted by XJ_Wang View Post
Hi Trailer
Best
Xiangjie
Hi Xiangjie,
Unfortunatly, no.
If you came across it, please let me know!
Old   March 29, 2023, 12:18
Xiangjie Wang
Hi Trailer,
Here is my personal understanding:
autoMap and rmap are used for parallel computing but they are not always needed. As you have mentioned, the parabolic velocity library(which is very popular in the tutorials) does not use these two functions, that is because there is no parameters needed to be decomposed. For example, when using DFSEM from OpenFOAM.com, the R, L values need to be decomposed because they are tensorField or scalarField type data. If there is no this kind of data/parameters, you don't need to use these two functions.
Time-varying boundary condition yurifrey OpenFOAM Programming & Development 35 February 17, 2021 08:35
timeVaryingMappedFixedValueFvPatchField for Traction control at boundaries Hisham OpenFOAM Programming & Development 16 September 19, 2011 15:36
Question about rmap and automap and boundary condition nlc OpenFOAM 0 November 1, 2010 14:51
