Close-packing spheres natural convection diverging
Old   December 17, 2021, 17:01
Post Close-packing spheres natural convection diverging
cal
saidc. is on a distinguished road
I'm trying to solve a laminar flow natural convection case that close-packed geometry. The cylinder's wall adiabatic. The mesh generated with this steps:
  1. Generate sphere coordinates with desired porosity by DEM code (cemfDEM).
  2. Create spheres and neck bridges for contact points approach with SALOME and fuse all together.
  3. Generate 2D mesh with NETGEN 1D-2D algorithm with SALOME and export as a STL file (Images are attached).
  4. Create background cylinder with blockMesh and create 3D grid with snappyHexMesh with desired features such as max-nonorthogonality < 55.
Necks image: https://ibb.co/xqqkbg9
2D mesh image: https://ibb.co/Nsv8n68
checkMesh results attached. For quick answer:
  • 43 million cells (snapping start with 1 millon background cells)
  • Max-nonorthogonality < 55 and average is 17
  • Some (10-20) skewed faces.
buoyantPimpleFoam Solver settings are:
  • 1e-6 p_rgh and 1e-8 U tolerance
  • 1 nNonOrthogonalCorrectors
  • 3 nCorrectors
  • 1000 nOuterCorrectors
  • relaxationFactors p_rgh --> 0.3 and others -->0.7
Initial conditions are:
  • U (0 0 0)
  • p_rgh (1 atm)
  • T (fluid: 293K and spheres: 393K)
The problem is, pressure diverges and time step contuinity error is increases. After 50th inner iteration solver blows up. I tried change schemes (increased most robust to accurate ones), reducing tolerances, decreasing time step (1e-12 to 1e-21) but non of them helped. If I try to decreasing tolerances for control TSCE, pressure iterations reaches max and diverges.
Boundary conditions seem right to me but I know that if TSCE increases this is mostly related to BCs.
I'm open to suggestions. Files are attached.
Kind regards,
Said.
saidc. is offline   Reply With Quote
Old   December 21, 2021, 07:12
cal
Update,
Instead of using the boussinesq approximation and other equationOfStates in thermophysicalProperties, I changed the solver to buoyantBoussinesqPimpleFoam and it runs smooth for now. Really interesting.
But I don't think the results will be good because in this case the temperature difference is 100 K. Let's see what happens. I'll keep update.
Kind regards,
Said.
buoyantpimplefoam, natural convection, packed bed, sphere
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 17:00
Natural Convection Problem - Helium marzoa STAR-CCM+ 0 April 18, 2011 15:12
CFX Natural Convection, please help. dbecker CFX 5 October 13, 2010 20:07
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
